RAServer error under Kubuntu [message #47153] |
Sat, 17 December 2005 07:39 |
Originally posted by: flocondeson.yahoo.com
I'm trying to run RAServer under Kubuntu 5.10 (Breezy). I installed
the package libstdc++2.10-dev, which contains the required library
libstdc++-libc6.2-2.so.3. When I start the server I get:
Starting Agent Controller
*** glibc detected *** free(): invalid next size (normal): 0x0805d0f0 ***
RAServer failed to start
If I set the environment variable MALLOC_CHECK_ to 1 I get:
malloc: using debugging hooks
*** glibc detected *** free(): invalid pointer: 0x0805d100 ***
*** glibc detected *** free(): invalid pointer: 0x08084990 ***
*** glibc detected *** malloc(): memory corruption: 0x08070c60 ***
RAServer started successfully
Even though it has started, Eclipse can't connect to it (which is
probably not surprising).
Has anyone seen this error and do you have a workaround, or
suggestions for what to look at?
There was a thread in October 2005 about Ubuntu that suggested
using alien to convert an RPM containing the libstdc++ library
mentioned above. Anyone know if that worked?
- Flocon
FUDForum. Page generated in 0.03592 seconds
