Home » Eclipse Projects » Remote Application Platform (RAP) » Some questions on RAP
Some questions on RAP [message #47083] |
Thu, 13 September 2007 18:47 |
Originally posted by: abo.splitshade.de
its a wonderful Newsgroup you?ve got here. I have quite a huge amount of
questions, and I try to simply ask them now;)
I tried to go through the sourcecode for RAP to discover some secrets,
1. I tried to debug the RAP engine, not an Application written with RAP,
but the RAP itself (in this case, i wanted to debug the RWT-Library). I
got an error, that the debugger could not find any linenumbers, so debug
doesn?t work as good as suspected. Is there a library, which is compiled
so that debugging works correctly? Or can i compile the library myself?
Or am I just too stupid?
2. I read, that RAP uses the ServletBridge to use Osgi on the Server.
I must admit, i didn?t really understand how this works.
I looked at the SourceCode for the ServletBridge, but I can?t manage to
understand it;), as far as i have understood this, the servletbridge
works as a dispatcher for the requests coming from other pcs to the
OSGI-Framework.
So the Servlet Bridge manages a Frameworklauncher, which loads the
Osgi-Runtime on the Server. Is that correct?
In the SourceCode, I read that it is possible to register a single
Servlet with the BridgeServlet. But I thought, if you want to use the
OSGI-Service, you write your Application and register a Servlet from
your Application with the Bridge, and the Bridge dispatches the requests
from and to the Osgi-Framework.
So as I told you, I really didn?t understand the background, any help is
appreciated.
3. I tried to understand, how the rendering in RAP works.
I managed to read a huge amount of code. What I couldn?t find is the
Point, where the Request from a Client is mapped to the LifeCycle in
RAP. So, what i would really love is a technical Overview, how this
stuff works?
As far as I could read from the sourcecode, repaint-events from the
server are sent to the client only, if the state of the component has
changed in some way.
But where in the source can I find the pieces where the communication
between the client and the server takes action?
If anybody wants to explain or has a link for that, my biggest thanks
are sure;)
4. I read, that there should be a online help for rap somewhere, but i
can?t manage to find it? Is this help included in eclipse and i made a
mistake in installing it? or is this help somewhere online on
http://eclipse.org/rap?
puh, this was a lot of stuff, but i hope, someone has the time to go
through it, thank you very much;)!
Bye
Re: Some questions on RAP [message #47148 is a reply to message #47083] |
Thu, 13 September 2007 22:02 |
Benjamin Muskalla Messages: 237 Registered: July 2009 |
Hi Martin,
thanks - nice you like RAP land ;)
Maybe I cannot answer every detail but let me try ...
Martin Dilger wrote:
Ok...normally that should be no problem. When working with CVS you
already have all sources. If you're working against the target runtime
it should be no problem either as we provide all sources (at least for
the RAP-specific plugins).
Or do you mean the qooxdoo library?
If yes, you can add -Dorg.eclipse.rwt.clientLibraryVariant=DEBUG to your
launch configuration to have a "debuggable" version of qooxdoo at runtime.
> OSGI-Framework.
> appreciated.
There are some informations about server-side equinox and the servlet
bridge available at http://www.eclipse.org/equinox/server/
> stuff works?
Jochen and Frank gave a talk at EclipseCon 2007 about RAP. The slides
are available here:
http://eclipsezilla.eclipsecon.org/php/attachment.php?bugid= 3833
The servlet which manages all incoming requests is
org.eclipse.ui.internal.servlet.RequestHandler which in the end calls
RWTLifeCycle#execute which goes trough all available phases (see slides).
That's an easy one ;-)
Imagine you have a widget X. The corresponding adapter between the
widget and the lifecycle is called a LifeCycleAdapter (LCA). So for
widget X you'll find a XLCA which has methods for every phase (see
slides). The LCA is responsible for initializing the widget on the
client side (renderInitialization), to render the changes since the last
request (renderChanges), to preserve the values to avoid sending the
data out everytime (preserveValues) and last but not least "readData"
which cares about the other way around as you can process events here
which are triggered on the client.
I think after looking at some of the LCA implementations it should be
easy to have a overview what's possible.
> are sure;)
There is a help plugin in CVS but we will make it available online
before the 1.0 release.
yet, that was a lot ;)
Nice you're so interested in RAP. Next time such question could better
be asked on the mailing list as most of the stuff is mostly relevant for
RAP developers.
> Bye
Have a nice day!
Benny
Current Time: Fri Sep 27 01:45:47 GMT 2024
Powered by FUDForum. Page generated in 0.03297 seconds
