Re: Breakpoints in anything but first page do not work [message #47829 is a reply to message #47769] |
Wed, 29 August 2007 12:38  |
Originally posted by: rge.comcast.net
Yes, I found the same thing. Thanks everyone for all of your help.....
"Daniel Serodio" <dserodio@gmail.com> wrote in message
news:fb3q79$pkp$1@build.eclipse.org...
>I use Zend debugger, but had a similar problem that I solved by using
> Firefox instead of the (eclipse builtin) IE.
> HTH,
> Daniel Serodio
> Ron wrote:
>> Thanks for your reply, it is very helpful. Is there anyone who has
>> figured
>> out how to propagate the XDEBUG_SESSION to subsequent page requests?
>> "Marijn van Zon" <marijn@suninet.org> wrote in message
>> news:fb11lu$sul$1@build.eclipse.org...
>>> This is because the debugger only runs for a single "page". So when the
>>> page is done loading the debugger stops. If it doesn't (haven't been
>>> able
>>> to debug myself yet due to other issues that are not PDT related) it
>>> might
>>> this a problem with the request strings needed for XDebug not being
>>> propagated.
>>> In order to "activate" XDebug eclipse sends something along the lines of
>>> ?XDEBUG_SESSION=......&XDEBUG_KEY= with the url that is used to
>>> load/debug
>>> the page. When the page is loaded the links on the pages themselves will
>>> not contain this and this when you click on a link the debugger is not
>>> fired up. You could copy/paste the links and append the XDEBUG
>>> information
>>> to them and open the pages manually. Another option is to enable the
>>> xdebug autostarter in your xdebug.ini. Not sure if this can be set from
>>> a
>>> user environment (as is possible with at least remote_host and
>>> remote_port). Also I'm not sure if eclipse will accept this (as the key
>>> will be different, you can set the session name to just "ECLIPSE" or
>>> whatever eclipse gives with it).
>>> Regards,
>>> Marijn.
>>> Ron wrote:
>>>> I set breakpoints in numerous files. Actually, the problem I am having
>>>> is when I try to break into a file which is loaded as a result of my
>>>> clicking on a link. If I just set breakpoints in files which are
>>>> included, the debugger stops at the breakpoints but not when the page
>>>> is
>>>> loaded as a result of interacting with the browser.
>>>> Thanks for your help...
>>>> I set breakpoI did a little more testing and found that, the
>>>> breakpoints
>>>> work if kthe *.php file
>>>> "Dave Kelsey" <dkel50@hotmail.com> wrote in message
>>>> news:fb0v3s$m0a$2@build.eclipse.org...
>>>>> Are breakpoints set in these other files ? or are you only using the
>>>>> option
>>>>> of break in first line ?
>>>>> Dave Kelsey
>>>>> Ron wrote:
>>>>>> I must be missing something. I can start the XDebug and have it
>>>>>> break
>>>>>> in the first file but not any other files which are referenced and
>>>>>> loaded?
FUDForum. Page generated in 0.05667 seconds
