Home » Archived » Visual Editor (VE) » SWT isn´t working
SWT isn´t working [message #46707] Sun, 04 July 2004 18:52 Go to next message
Alessandro Fragnani is currently offline Alessandro FragnaniFriend
I have installed VEP 1.0 on Eclipse v3.0 Oficial release, but the visual
design doesn´t work.
I followed the installations instructions (copy to eclipse "features"
and "plugins" folders), and it appears on Help / About / Feature
details. I create a "File / New / Other / Visual Class", and select
"Superclass as java.lang.Object", as says on the
" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/newAndNoteworthy/1.0.0-M1/previewi ngSWT.html"
and the "SWT group" appears as expected. But when I try to put a
"Shell", or any other widget, it only appears an icon like beans, and
the widget name below.
Any idea about this problem?
Did I downloaded the right packages?
I donloaded:
VE-runtime-S20040628 (VE-runtime-S20040628.zip)
GEF-runtime-3.0 (GEF-runtime-3.0.zip)
emf-sdo-runtime-2.0.0 (emf-sdo-runtime-2.0.0.zip)
Some ideas?
Thanks in advance
Alessandro
Re: SWT isn´t working [message #47219 is a reply to message #46707] Tue, 06 July 2004 03:30 Go to previous message
Using the tip that Jeff Myers told me on post above the SWT visual
design seems to work fine.
He told me to delete the "configuration" folder and restart Eclipse.
I guess that it should be documented somehow.
Thanks for the help.
Alessandro
Alessandro Fragnani wrote:
> I donloaded:
> Some ideas?
> Thanks in advance
> Alessandro
Re: SWT isn´t working [message #594258 is a reply to message #46707] Tue, 06 July 2004 03:30 Go to previous message
Alessandro
> I donloaded:
> Some ideas?
> Thanks in advance
> Alessandro
Previous Topic:non-integrated layout manager not laying out
Next Topic:It´s too hard to work with VEP using SWT :-(
Current Time: Thu Dec 26 19:32:16 GMT 2024
Powered by FUDForum. Page generated in 0.03335 seconds
