Home » Eclipse Projects » Nebula » Problem with shell closing after the grid drag detection mechanism being enabled and some grid colum
Problem with shell closing after the grid drag detection mechanism being enabled and some grid colum [message #46696] |
Wed, 16 January 2008 09:17  |
Originally posted by: vye.maconomy.dk
Hi guys,
I faced the following problem: when I enable drag detection mechanism in
the grid and then click on some grid column header, then I cannot close
immediately the grid's shell: the first mouse click after click on the
header activates the shell, and only the second click on the
application's close button closes the application. This happens under
Windows platform. Here is the snippet for this problem (actually this is
GridSnippet1, modificated for drag detection support of the grid):
package snippets;
import org.eclipse.nebula.widgets.grid.Grid;
import org.eclipse.nebula.widgets.grid.GridColumn;
import org.eclipse.nebula.widgets.grid.GridItem;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.DragDetectEvent;
import org.eclipse.swt.events.DragDetectListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
* Creates a simple grid and a button for focusing and selection of
* the first cell of the grid. */
public class Snippet001GridDragDetectListener {
* Main entry.
* @param args command line arguments
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
final Grid grid = new Grid(shell, SWT.BORDER | SWT.V_SCROLL |
SWT.H_SCROLL);
grid.setHeaderVisible(true);
final GridColumn column = new GridColumn(grid, SWT.NONE);
column.setTree(true);
column.setText("Column 1");
column.setWidth(100);
final GridItem item1 = new GridItem(grid, SWT.NONE);
item1.setText("Root Item");
final GridItem item2 = new GridItem(item1, SWT.NONE);
item2.setText("Second item");
final GridItem item3 = new GridItem(item2, SWT.NONE);
item3.setText("Third Item");
// The following code was inserted to enable
// drag detection listening mechanism
// in the grid.
grid.setDragDetect(true);
// If you add at least one drag detection listener
// to the grid and then click on the grid column
// header, then the grid's shell loses its active state,
// that is, for example, you cannot then close the
// demo with one mouse click (first mouse
// click afterwards activates the grid's shell, and
// only second mouse click closes the demo itself).
grid.addDragDetectListener(new DragDetectListener() {
/** {@inheritDoc} */
public void dragDetected(final DragDetectEvent event) { }
shell.setSize(200, 200);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Does somebody know why it might be the case?
Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #46777 is a reply to message #46696] |
Thu, 17 January 2008 10:06   |
Hi Vadym,
This was a bug. I've fixed it. Please download a new build and verify
that it works.
-Chris
Vadym Yepishov wrote:
> Hi guys,
> package snippets;
> import org.eclipse.swt.widgets.Display;
> * Main entry.
> public static void main(String[] args) {
> SWT.H_SCROLL);
> // in the grid.
> shell.open();
> display.sleep();
> display.dispose();
> Best regards,
> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #47044 is a reply to message #46777] |
Fri, 18 January 2008 04:38   |
Hi Chris,
Unfortunately the bug can still be reproduced under the new build.
Please use the snippet described in my letter and do the following steps:
1) open the demo;
2) click on the grid column header;
3) click on the "close" button of the demo.
Actual result: the demo is not closed (the "close" button just becomes
active).
Expected result: the demo should be closed.
Hope you will find the source of the problem:)
Vadym Yepishov
Chris Gross wrote:
> Hi Vadym,
> that it works.
> -Chris
>> Hi guys,
>> in the grid and then click on some grid column header, then I cannot
>> close immediately the grid's shell: the first mouse click after click
>> on the header activates the shell, and only the second click on the
>> is GridSnippet1, modificated for drag detection support of the grid):
>> package snippets;
>> * Main entry.
>> SWT.H_SCROLL);
>> // in the grid.
>> shell.open();
>> display.sleep();
>> display.dispose();
>> Best regards,
>> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #47560 is a reply to message #47044] |
Sun, 27 January 2008 09:54   |
I can't reproduce this again. Are you sure you downloaded the new
build? Could you try downloading a new build again?
-Chris
> Hi Chris,
> 1) open the demo;
> active).
> Best regards,
> Vadym Yepishov
> Chris Gross wrote:
>> Hi Vadym,
>> verify that it works.
>> Regards,
>> -Chris
>>> Hi guys,
>>> package snippets;
>>> * Main entry.
>>> SWT.H_SCROLL);
>>> // in the grid.
>>> shell.open();
>>> display.sleep();
>>> display.dispose();
>>> Best regards,
>>> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #47817 is a reply to message #47560] |
Mon, 28 January 2008 07:06  |
Hi Chris,
Thanks for your help. The defect is fixed now.
Vadym
> -Chris
>> Hi Chris,
>> 1) open the demo;
>> active).
>> Best regards,
>> Vadym Yepishov
>> Chris Gross wrote:
>>> Hi Vadym,
>>> Regards,
>>> -Chris
>>>> Hi guys,
>>>> mechanism in the grid and then click on some grid column header,
>>>> then I cannot close immediately the grid's shell: the first mouse
>>>> click after click on the header activates the shell, and only the
>>>> second click on the application's close button closes the
>>>> application. This happens under Windows platform. Here is the
>>>> snippet for this problem (actually this is GridSnippet1, modificated
>>>> package snippets;
>>>> * Main entry.
>>>> | SWT.H_SCROLL);
>>>> // in the grid.
>>>> shell.open();
>>>> display.sleep();
>>>> display.dispose();
>>>> Best regards,
>>>> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #587745 is a reply to message #46696] |
Hi Vadym,
that it works.
-Chris
> Hi guys,
> package snippets;
> * Main entry.
> SWT.H_SCROLL);
> // in the grid.
> shell.open();
> display.sleep();
> display.dispose();
> Best regards,
> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #587826 is a reply to message #46777] |
Hi Chris,
1) open the demo;
active).
Vadym Yepishov
Chris Gross wrote:
> Hi Vadym,
> that it works.
> -Chris
>> Hi guys,
>> package snippets;
>> * Main entry.
>> SWT.H_SCROLL);
>> // in the grid.
>> shell.open();
>> display.sleep();
>> display.dispose();
>> Best regards,
>> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #587979 is a reply to message #47044] |
-Chris
> Hi Chris,
> 1) open the demo;
> active).
> Best regards,
> Vadym Yepishov
> Chris Gross wrote:
>> Hi Vadym,
>> Regards,
>> -Chris
>>> Hi guys,
>>> package snippets;
>>> * Main entry.
>>> SWT.H_SCROLL);
>>> // in the grid.
>>> shell.open();
>>> display.sleep();
>>> display.dispose();
>>> Best regards,
>>> Vadym Yepishov
Re: Problem with shell closing after the grid drag detection mechanism being enabled and some grid c [message #588081 is a reply to message #47560] |
Hi Chris,
Vadym
> -Chris
>> Hi Chris,
>> 1) open the demo;
>> active).
>> Best regards,
>> Vadym Yepishov
>> Chris Gross wrote:
>>> Hi Vadym,
>>> Regards,
>>> -Chris
>>>> Hi guys,
>>>> package snippets;
>>>> * Main entry.
>>>> | SWT.H_SCROLL);
>>>> // in the grid.
>>>> shell.open();
>>>> display.sleep();
>>>> display.dispose();
>>>> Best regards,
>>>> Vadym Yepishov
Current Time: Thu Mar 13 13:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.05012 seconds
