Home » Archived » BIRT » memroy leak not detected/memory profiler stopping?
memroy leak not detected/memory profiler stopping? [message #46657] Wed, 15 June 2005 18:57 Go to next message
Originally posted by: lbmes2000.yahoo.com
Hi all
Im using tptp 4.0. When I start memory profiling everything works fine --
i am able to call up instance info and whatnot. After a number of
refreshes, however, the memory profiler claims there is no info and I have
to start recollecting info, losing all the previosly gathered info.
Eventually both eclipse and the program suffer OutOfMemoryError meessages.
While the profiler is working, it does not appear that the program is
leaking memory, the number of live instances for any particular class does
not grow. I get the OOM for the application when I run it from the
command line as well.
I am running under linux. I am not clicking the option that warns about
exponential memory growth (instance level info), and I do not have any
limits set. Here is what shows up on the command line when eclipse
collapses.
java.lang.OutOfMemoryError
Unhandled event loop exception
Reason:
Failed to execute runnable (java.lang.OutOfMemoryError)
*** SWT nested exception
Reason:
Re: memroy leak not detected/memory profiler stopping? [message #46676 is a reply to message #46657] Wed, 15 June 2005 19:12 Go to previous messageGo to next message
Hi, Michael,
Can you provide more information on what you did with BIRT? That is, what
report you are running, how large the data set is, what operations you are
performing. Seems that your description is quite detailed when it comes to
profiling, but is missing details on the report side (as you only
mentioned "the application", "after a few refreshes")? Thanks.
Stanley Wang
BIRT Engine
Re: memroy leak not detected/memory profiler stopping? [message #46877 is a reply to message #46657] Wed, 15 June 2005 23:07 Go to previous message
sorry wrong group! My bad.
Previous Topic:Commons-logging
Next Topic:Error1:Cannot open connection (jdbc) in Report Design /Preview
Current Time: Fri Oct 31 00:04:01 EDT 2025
Powered by FUDForum. Page generated in 0.03558 seconds
