Home » Language IDEs » C / C++ IDE (CDT) » Debugger Timeout
| Debugger Timeout [message #46578] |
Wed, 23 October 2002 08:58  |
Originally posted by: ili.inbox.ru
I'm having a trouble with CDT Debugger.
I use W2K, Eclipse 2.0.1, CDT build 20021022. I have Cygwing installed
properly, and it is in the PATH.
My C++ program builds fine also. But when I try to debug something,
I always get the following error message:
Failed Launching CDI Debugger: Error Inintiallizing : Timedout
If anyone could suggest what could be wrong here?
Thanks a lot.
| Re: Debugger Timeout [message #46627 is a reply to message #46603] |
Wed, 23 October 2002 09:46   |
Thanks for your quick respond, Igor.
When I laung gdb from the command line outside Cygwin/bin, it works just
fine. It launches graphical interface though, by default, and I\'m able to
debug
with gdb.
Also, in my Launch Configuration Panel, I have two options:
C/C++ application, C/C++ Post-morten Debugger. Which one should I use?
If I choose C/C++ application, for example, then I find my project through
\"Browse\" button. The Browse button for the C/C++ Application does not
show
me anything available, but when I type the name of the exectutable, it
finds it. Then I press Apply, Debug, and the exeption message appears.
In the Debugger Panel, I have the following:
Debugger: GDB Debugger
Run Program in debugger is selected.
Stop at main on startup is checked.
MI Debugger: gdb
Maybe these are not correct options?
Thanks again for your help.
Sincerely,
Ilya
Igor S. Zamyatin wrote:
> It\'s very strange. May be you didn\'t correctly input all launch info
> into Launch Configuration page or may be inspite of correct path to cygwin
> path to gdb is incorrect. Try to launch it from command line somewhere out
> of Cygwin folder.
> Hope it helps,
> Igor S. Zamyatin
> Interstron Ltd.
> email: isz@interstron.ru
> tel: +7 (095) 269-4713
> cell: +7 (902) 659-5838
> www: http://www.interstron.ru
> > Hi,
> > I\'m having a trouble with CDT Debugger.
> > Thanks a lot.
| Re: Debugger Timeout [message #46648 is a reply to message #46627] |
Wed, 23 October 2002 10:12   |
Everything is correct and you have to choose "C/C++ application". I
think the problem is that you have wrong version of gdb. CDT works with
5.2.1 gdb.
Check your version of GDB, please.
Igor S. Zamyatin
> debug
> with gdb.
> show
> MI Debugger: gdb
> Sincerely,
> Ilya
> > of Cygwin folder.
> > Hope it helps,
> > Igor S. Zamyatin
> > Interstron Ltd.
> > > Hi,
> > > Thanks a lot.
| Re: Debugger Timeout [message #46697 is a reply to message #46648] |
Wed, 23 October 2002 11:08   |
"Igor S. Zamyatin" <isz@interstron.ru> wrote in message
news:ap6anv$qhr$1@rogue.oti.com...
| 5.2.1 gdb.
The CDT uses GDB version 5.2.1 as the default. If you are using Cygwin the
default version they currently install is too old. You need gdb 5.2.1, which
should be in the gdb package dated 20020718-1
-Judy
| Igor S. Zamyatin
to
| > debug
| > with gdb.
through
| > show
| > MI Debugger: gdb
| > Sincerely,
| > Ilya
info
cygwin
out
| > > of Cygwin folder.
| > > Hope it helps,
| > > Igor S. Zamyatin
| > > Interstron Ltd.
| > > > Hi,
installed
| > > > Thanks a lot.
| Re: Debugger Timeout [message #46708 is a reply to message #46697] |
Wed, 23 October 2002 10:51   |
Now I've installed GNU gdb 2002-07-19-cvs (cygwin-special).
And I'm getting some different behaviour.
When the debugger starts, I see two processes now:
GDB Debugger and MyProject.exe,
But it doesn't do anything. I mean, it does not stop at my breakpoints.
Also, I'm only allowed to use Terminate from the Run menu (step into, etc
are not enabled).
Am I doing something wrong again?
Ilya
> | 5.2.1 gdb.
> -Judy
> | Igor S. Zamyatin
> to
> | > debug
> | > with gdb.
> through
> | > show
> | > MI Debugger: gdb
> | > Sincerely,
> | > Ilya
> info
> cygwin
> out
> | > > of Cygwin folder.
> | > > Hope it helps,
> | > > Igor S. Zamyatin
> | > > Interstron Ltd.
> | > > > Hi,
> installed
> | > > > Thanks a lot.
| Re: Debugger Timeout [message #46800 is a reply to message #46753] |
Wed, 23 October 2002 11:54   |
Sam Robb wrote:
> Ilya,
> Can you explain the permissions problem you saw, and how you solved it?
> -Samrobb
Sam,
The permissions problem occured after I've installed new versions of
gcc/gdb from Cygwin. I've just compiled my project from the command line,
and
tried to execute it. I got "Access is denied." message.
Then, I went to properties of the executable, and set Execute permission.
The debugger worked fine, after that.
Now, I can't figure out, why gcc produces the file with such permissions.
Are you haveing the same problem?
| Re: Debugger Timeout [message #46887 is a reply to message #46800] |
Wed, 23 October 2002 15:53  |
> and
Ah, I see... if you have recently upgraded your version of Cygwin
(in the past two weeks or so), there's a known problem that results
in gcc producing non-executable files. You might want to take a
look at the Cygwin mailing list; IIRC, part of the problem is having
an incorrect /etc/passwd file.
-Samrobb
Current Time: Mon Oct 27 21:59:22 EDT 2025
Powered by FUDForum. Page generated in 0.06306 seconds
