Home » Eclipse Projects » Eclipse Platform » eclipse not handling international chars
eclipse not handling international chars [message #46546] Fri, 23 May 2003 14:06 Go to next message
Originally posted by: emerson.tre-sc.gov.br
Hi, i've been here with this problem, but i still didn't solve it.
Eclipse look like not handling the enconding (ISO-8859-1) right. I've put
the enconding at workbench->editors->text file encoding.but it looks like
using the defalut, event when running ant inside elcipse it doens't take
it in account, so I have to put enconding in every task, as javac,
replace, copy, or ir loose my portuguese char.
Other problem very strange is when i copy and paste these chars Eg:
conexões , after copy and paste turn in conex\x{00F5}es
any clue?
Thanks in advance
Emerson
Re: eclipse not handling international chars [message #46772 is a reply to message #46546] Fri, 23 May 2003 15:04 Go to previous messageGo to next message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Fri, 23 May 2003 18:06:30 +0000 (UTC), emerson@tre-sc.gov.br
In the javac task you need to add: encoding="ISO-8859-1". Look at the
javac task documentation.
http://ant.apache.org/manual/index.html
Olivier
Re: eclipse not handling international chars [message #47035 is a reply to message #46772] Fri, 23 May 2003 16:53 Go to previous messageGo to next message
thanks olivier, but I already do that, I think that there must be a way to
ant using the default econding, and make the default use the ISO-8859-1.
And what about the copy and paste problem i told before?
exceção -> exce\x{00E7}\x{00E3}o
> Olivier
Re: eclipse not handling international chars [message #54426 is a reply to message #46546] Thu, 29 May 2003 13:22 Go to previous message
Originally posted by: knut_radloff.oti.com
"Emerson" <emerson@tre-sc.gov.br> wrote in message news:balnv5$35k$1@rogue.oti.com...
> conex
Previous Topic:How to make buttons on JFace dialog
Next Topic:Including icons in a plug-in
Current Time: Sun Nov 02 12:41:07 EST 2025
Powered by FUDForum. Page generated in 0.10295 seconds
