Home » Eclipse Projects » Technology Project and PMC » "unexpected end of file" build error
"unexpected end of file" build error [message #46452] Wed, 19 February 2003 13:35 Go to next message
When I'm compiling my project, I get several hundred "unexpected end of
file" build errors. The reason this is coming up is because at the end
of the classes, there is CVS specific information which is commented
out. For some reason, the compiler does not like this information being
there if it isn't trailed with a return character so that there is one
blank line at the end of the document. Here's some explamples:
Doesn't Work(the error will appear on the last line):
===START OF FILE
public class MyClass{
//Revision 1.1 Added class to CVS
===END OF FILE
Works Fine: (note the empty line before End of File)
===START OF FILE
===END OF FILE
Any clues on how I can get the compiler to ignore this kind of stuff?
thanks,
-Dennis
Re: "unexpected end of file" build error [message #46565 is a reply to message #46452] Thu, 20 February 2003 04:08 Go to previous messageGo to next message
Forgot to mention that this only happens in "compiler compliance level" for
jdk 1.4. I need jdk 1.4 compliance for asserts we're using.
"Dennis Warren" <notrash98@hotmail.com> wrote in message
news:b30h5s$625$1@rogue.oti.com...
> ===START OF FILE
> file://Revision 1.1 Added class to CVS
> ===END OF FILE
> ===START OF FILE
> ===END OF FILE
> thanks,
> -Dennis
Re: "unexpected end of file" build error [message #46590 is a reply to message #46565] Thu, 20 February 2003 09:32 Go to previous messageGo to next message
I would post this to eclipse.tools where the compiler committers are much
more likely to address the issue.
Darins
news:b323j0$7tf$1@rogue.oti.com...
for
> > ===START OF FILE
> > ===END OF FILE
> > ===START OF FILE
> > ===END OF FILE
> > thanks,
> > -Dennis
Re: "unexpected end of file" build error [message #46614 is a reply to message #46590] Thu, 20 February 2003 11:10 Go to previous messageGo to next message
Thanks!
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:b32n8m$pap$1@rogue.oti.com...
> Darins
> for
of
end
being
> > > ===START OF FILE
> > > ===END OF FILE
> > > ===START OF FILE
> > > ===END OF FILE
> > > thanks,
> > > -Dennis
Re: "unexpected end of file" build error [message #46899 is a reply to message #46452] Mon, 24 February 2003 11:34 Go to previous message
I believe Java 1.4 changed the spec to say that a comment can't end with
EOF. So you need a newline at the end of the comment. I don't know if
there's a compiler switch to revert back to the 1.3 style.
> file" build errors.
Re: "unexpected end of file" build error [message #590626 is a reply to message #46452] Thu, 20 February 2003 04:08 Go to previous message
> ===START OF FILE
> ===END OF FILE
> ===START OF FILE
> ===END OF FILE
> thanks,
> -Dennis
Re: "unexpected end of file" build error [message #590638 is a reply to message #46565] Thu, 20 February 2003 09:32 Go to previous message
Darins
for
> > ===START OF FILE
> > ===END OF FILE
> > ===START OF FILE
> > ===END OF FILE
> > thanks,
> > -Dennis
Re: "unexpected end of file" build error [message #590647 is a reply to message #46590] Thu, 20 February 2003 11:10 Go to previous message
Thanks!
> Darins
> for
of
end
being
> > > ===START OF FILE
> > > ===END OF FILE
> > > ===START OF FILE
> > > ===END OF FILE
> > > thanks,
> > > -Dennis
Re: "unexpected end of file" build error [message #590740 is a reply to message #46452] Mon, 24 February 2003 11:34 Go to previous message
> file" build errors.
Previous Topic:how to set up Eclipse & JBoss to hotswap
Next Topic:how to build modified Java files only
Current Time: Tue Jul 01 09:00:29 EDT 2025
Powered by FUDForum. Page generated in 0.29527 seconds
