Home » Language IDEs » ServerTools (WTP) » XML Parsing Question
XML Parsing Question [message #46394] Tue, 28 September 2004 20:18
Originally posted by: jai.kejriwal.air2web.com
I need to do the following.
While the user edits some code in a workflow document (in XML) and is in the
process of adding a certain XML tag that corresponds to a variable defined
in a data definition file, I need my plugin to pop up a dialog box if it
cannot find that variable defined in the data definition file.
My guess is that I will need to have some kind of parser active while the
user is editing the workflow document that will search the list of variables
in the data defn. file once the user has finished typing the tag. I don't
know how to go about doing this.
Your help is highly appreciated.
Thanks.
Previous Topic:Can not generate WS Client from Amazon's WS
Next Topic:[BUGZILLA] - Component: "Java Standard Tools" => "J2EE Standard Tools"
Current Time: Wed Jan 15 10:01:20 GMT 2025
Powered by FUDForum. Page generated in 0.05133 seconds
