Home » Language IDEs » PHP Development Tools (PDT) » How to find out debug_session_id?
How to find out debug_session_id? [message #46358] Sat, 25 August 2007 07:11 Go to next message
Originally posted by: cryogenesis.gmail.com
I'm currently trying to migrate from Zend Studio to PDT and I use Zend's
Firefox plugin to debug from within the browser (I'm using Zend Debugger
btw). Unfortunately, though, PDT seems to require a parameter that Zend
Studio didn't -- debug_session_id .
I can find out the current id if I "debug as PHP Webpage" in Eclipse,
and then check the get parameters. I set the debug_session_id value to a
modified version of the plugin I made (so it will be sent by a cookie)
and debug will then work from within Firefox.
There are two problem with this approach:
1- PDT won't accept any debug_session_id unless I use 'debug as php web
page' once after every Eclipse launch.
2- I see no way to automatize the discovery/generation of this id.
So I was wondering if there is a way to query PDT and find out this
parameter.
Rafael
PS: is there a way to turn off browser output in the debug/php
perspectives? I find it annoying mainly because it uses IE, which gives
JS errors on my page (i'm aiming for firefox only in this iteration).
Re: How to find out debug_session_id? [message #46448 is a reply to message #46358] Sun, 26 August 2007 11:29 Go to previous messageGo to next message
Originally posted by: reply-to-newsgroup.news.com
The Zend Toolbar works only with Zend products (e.g. Zend Studio).
It will not work with the PDT.
Shalom Gibly
Zend
"Phenøm" <cryogenesis@gmail.com> wrote in message
news:faokiq$86b$1@build.eclipse.org...
> Hi
> I can find out the current id if I "debug as PHP Webpage" in Eclipse, and
> modified version of the plugin I made (so it will be sent by a cookie) and
> parameter.
> Rafael
> perspectives? I find it annoying mainly because it uses IE, which gives JS
Re: How to find out debug_session_id? [message #46557 is a reply to message #46448] Sun, 26 August 2007 17:44 Go to previous messageGo to next message
I got it to work with PDT, the only thing missing is a way to get said
parameter automatically.
So I guess there is no way of getting debug_session_id from an external
application (or no way to omit it altogether)?
Rafael
> Shalom Gibly
> Zend
Re: How to find out debug_session_id? [message #46583 is a reply to message #46557] Mon, 27 August 2007 08:00 Go to previous messageGo to next message
Originally posted by: morgg.mail.com
The Zend debugger server component is the same for PDT and Zend Studio,
and they both rely on cookies for remote server debugging for all pages
in a domain. The debugger server sends a "Set cookie" header the first
time you request a page with the GET parameters to open a debug session
(if you have "Debug all pages" set in the Debug configuration you run in
Eclipse). After this, all the pages in the domain continue the debug
session based on this cookie.
I had a similar problem with a "no session id" in Eclipse. The problem
for me was in debuggin all pages of a session. I could debug just the
first page.
I eventually found the problem to be with cookies. I had the Suhosin
patch in my local Apache server, which was encrypting the cookies where
ZendDebugger stores its parameters and they couldn't be reported back
correctly to Eclipse.
I uninstalled Suhosin and everything is working now. Of course, no need
to use Zend's Firefox extension, and you don't have to worry about
session id's, you just select the debug configuration you have
configured in eclipse, and it will automatically start your preferred
external browser. Then you browse normally, and everytime you hit a
breakpoint, Eclipse will stop the server.
I hope you can get it to work, I was frustrated when I couldn't debug.
Marcos.
> Rafael
>> Shalom Gibly
>> Zend
Re: How to find out debug_session_id? [message #46718 is a reply to message #46583] Mon, 27 August 2007 23:06 Go to previous message
No Suhosin here, so I guess I'll just need to adapt and don't rely so
much on this extension.
Thanks for your reply.
Rafael
Previous Topic:Custom ide-tooltip-popup for functions
Next Topic:XDebug remote support
Current Time: Wed Jan 15 10:32:25 GMT 2025
Powered by FUDForum. Page generated in 0.03440 seconds
