| Home » Modeling » OCL » 2 OCL-EMF Integration Questions
 Goto Forum:|
| 2 OCL-EMF Integration Questions [message #46357] | Wed, 12 December 2007 03:19  |  |
| Eclipse User  |  |  |  |  | Hi.
 I have two questions:
 1. Access to a field, if the getter is overwritten
 We use OCL to define "derived" attributes, as in Christian Damus's
 Example. These attributes have derive=true, volatile=true,
 transient=true, changeable=false, and everything works well.
 Now, in EMF I can have derived attributes with only derive=true,
 but volatile=false, transient=false, changeable=false. In these
 attributes a derived getter will typically read the field.
 How is this possible in OCL? If the feature is called xyz, and
 the getter is getXyz(), what happens if I want to use xyz in
 the OCL derivation of getXyz()? Is xyz in ocl always translated into
 the getter, or does it try to find the field, and only then the getter?
 (follow up question: can I access EMF Operation getXyz2() as xyz2 in OCL??)
 2. Access to the super version of an operation
 We use OCL to define the  "body" of operations, as in Christian Damus's
 Example.
 If such an operation overrides one from the super class, how can I call
 in such an operation the super-version of the same operation?
 Thanks a lot in advance for any hint.
 Philipp Kutter
| Re: 2 OCL-EMF Integration Questions [message #46390 is a reply to message #46357] | Wed, 12 December 2007 08:26   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cdamus.ca.ibm.com
 Hi, Philipp,
 See some replies in-line, below.
 HTH,
 Christian
 Philipp W. Kutter wrote:
 > Hi.
 Does this really work?  I would expect this to confuse some parts of the EMF
 run-time, that would expect a derived property to be unchangeable.  I know
 that some corners of the GMF run-time make this assumption.
 The EcoreEvaluationEnvironment in MDT OCL uses EMF's reflective eGet() API
 to obtain a property's value.  EMF will usually generate an eGet() that
 calls the accessor method.  Java reflection is only used to invoke
 operations, as EMF provides no eCall(EOperation, EList<?>) API.
 > OCL??)
 If the Ecore model actually defines a getXyz2() operation, then OCL will
 have access to it.  If it is only the accessor method for a property, then
 OCL won't see it because it is simply a Java implementation pattern.
 > Example.
 If your OCL expression has a variable b of type B which specializes A, and B
 redefines an operation foo() and a property x from A, then you can invoke
 these features of A by casting:
 b.oclAsType(A).foo()
 b.oclAsType(A).x
 However, MDT OCL does not support this usage.  Indeed, as it is specified by
 OMG, it would be a little difficult to implement and has semantics
 inconsistent with variable initialization, anyway.  Consider that, using
 the above example, if the following indicates that we want to access A's
 definition of foo()
 then what does the following mean?
 let bAsA : A = b.oclAsType(A) in
 bAsA.foo()
 Should this invoke A::foo() or B::foo()?  I would expect the latter, for
 consistency with the following in which A additionally has a
 self-association A::relatedAs:
 a.relatedAs->collect(rel : A | rel.foo())
 In this case, one clearly expects that for any Bs in the collection of
 relatedAs, we would get B::foo() despite the fact that the rel variable's
 static type is A.
 > Philipp Kutter
| Re: 2 OCL-EMF Integration Questions [message #46537 is a reply to message #46390] | Wed, 12 December 2007 15:50   |  |
| Eclipse User  |  |  |  |  | Hi, Christian.
 Comments inline
 I asked the question on the emf group.
 Ok, thus there is no way to get to the property, if not through the getter.
 I know. I tried to get Ed on the topic again. All I found out, is that
 he would call it eInvoke. For the signature, I think it would be
 something like
 eInvoke(EOperation, EList<EArgument>
 where EArgument would be a wrapper for actual values for ETypes (in many
 and non-many versions of course). We will try to find time to work on this.
 >> OCL??)
 I understand. You always go over eGet() for the features, and you only
 add those operations to the OCL environment, which are declared in the
 EClass.
 >> Example.
 >   b.oclAsType(A).x
 > definition of foo()
 >     bAsA.foo()
 > static type is A.
 This I will send for feedback to Mariano Belaunde, the OCL chair. He is
 as well in my LinkedIn network, please let me know if you are interested
 to connect with him. By the way, it would be great, if we would see an
 integration of their OCL implementation with the MDT OCL implementation,
 similar to the way how TopcaseD is integrating with MDT.
 Best, Philipp
 >> Philipp Kutter
| Re: 2 OCL-EMF Integration Questions [message #46810 is a reply to message #46390] | Thu, 13 December 2007 15:39  |  |
| Eclipse User  |  |  |  |  | Eds comments regarding the first question:
 -------- Original Message --------
 Subject: Re: derived features with  volatile=false, transient=false,
 changeable=true
 Date: Wed, 12 Dec 2007 18:04:12 -0500
 Organization: EclipseCorner
 Newsgroups: eclipse.tools.emf
 References: <fjpg9i$jfn$1@build.eclipse.org>
 Philipp,
 Comments below.
 > Hi.
 > Are such features working?
 Where you define working how?
 > I asked on the OCL group, and someone asked, whether such a feature
 > would work.
 > I do not see any problem for such a feature. Is there one?
 You need to write the code for the methods.
 > Best, Philipp
 > the EMF
 > know
 It's assumed that derived properties are computed from other values, so
 they aren't copied, but as part of being computed they could be set and
 hence produce notification...
 Current Time: Thu Oct 30 22:56:33 EDT 2025
 Powered by FUDForum . Page generated in 0.05051 seconds |
