Home » Eclipse Projects » Nebula » Brainstorming: grid as a spreadsheet
Brainstorming: grid as a spreadsheet [message #46350] Fri, 11 January 2008 11:52 Go to next message
Originally posted by: sf.tragwerk-dresden.de
Hi all,
current table oriented widgets and their JFace-Viewers are all row
oriented. That means that the number of columns is fixed and each row
represents an (Business-)Object of the same type. This is ok for the
most data-centric applications, where you can focus on a (one
dimensional) collection of things.
But I think there *is* a need for viewers which are able to map a 2
dimensional oriented data-model to a table. So the number of rows *and*
the number columns should depend on the model's state. I think of
concerns in science ore related sectors. At least I have a need for it
(civil engineering).
I think Grid is a prefered Widget for that.
Currently I experimented myself with the existing Viewers and I am sure
I will get a solution - somehow.
But if there is real need from the comunity for that we need a more
professional solution.
Maybe Tom Schindl could give his 2 Cents as well as Chris Gross or Boris
Bokowski.
What is needed most is
a) a ContentProvider which does something like
public Object[][] getElements(Object input)
b) a Viewer which can create and dispose rows and columns on refresh()
c) a DataBinding support to observe (input-)model structure changes to
refresh the viewer
d) a cell oriented DataBinding support for CellEditors
Sebastian
Re: Brainstorming: grid as a spreadsheet [message #46382 is a reply to message #46350] Fri, 11 January 2008 12:24 Go to previous messageGo to next message
A few comments are below (although I need to think about this a bit more
Sebastian Fuchs schrieb:
> Hi all,
> Bokowski.
> refresh the viewer
If we could come together that a structural change to the 2 dimension
can only happen when a new input is set this is already supported by the
current databinding lib (see ObservableListContentProvider).
Already reality but not part of the databinding framework but the
changes in the JFace-API in 3.3 added the needed hooks ;-)
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet013TableViewerEditing.java?view=markup
I'll comment more on these and other points after having thought more
about it.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Brainstorming: grid as a spreadsheet [message #46470 is a reply to message #46382] Mon, 14 January 2008 03:50 Go to previous messageGo to next message
Tom, thank you for considering this.
1)
I am afraid, a structural change can not happen only on setInput().
Like in a one dimensional data structure, the number of items in a list
can change, but it is always the same list I want to show (= input).
I think it is a bad practise to manually set the same list as a new
input again when a structural change happens.
2)
.... [from snippet 13]
protected void initializeCellEditorValue(CellEditor cellEditor,
ViewerCell cell) {
Object modelElement = cell.getElement();
cell.getElements() returns the model object for the current *row*.
What I meant is, that each *cell* should have its own representing model
object. You are right, this is actually not a databinding concern but it
is related.
All my current approaches to get a 2 dimensional table to work mixed up
the current layers.
Sebastian
Tom Schindl schrieb:
more :-) .
>> Hi all,
sure I will get a solution - somehow.
Boris Bokowski.
to refresh the viewer
about it.
> Tom
Re: Brainstorming: grid as a spreadsheet [message #46501 is a reply to message #46470] Mon, 14 January 2008 08:43 Go to previous messageGo to next message
Would it be possible for you to share some piece of code (preferably a
snippet) so that I get a starting point and see the problems? Maybe I
can come up with a solution then :-)
Tom
> 1)
> 2)
> ViewerCell cell) {
> is related.
> the current layers.
> Sebastian
> > Hi,
> more :-) .
> >> Hi all,
> Boris Bokowski.
> about it.
> > Tom
Re: Brainstorming: grid as a spreadsheet [message #46631 is a reply to message #46501] Tue, 15 January 2008 03:57 Go to previous messageGo to next message
Today's approach looks promising.
I am about wrapping the existing viewers.
Thank you so long.
I will raise a new thread when I am forcing problems.
Sebastian
> Tom
Re: Brainstorming: grid as a spreadsheet [message #46652 is a reply to message #46501] Tue, 15 January 2008 06:20 Go to previous messageGo to next message
Tom,
it seems to work.
If you are interested in the code please let me know.
It's too complex to show it in a simple snippet.
Furthermore my comments are all in German.
sf [at] tragwerk-dresden.de
Sebastian
Re: Brainstorming: grid as a spreadsheet [message #46671 is a reply to message #46652] Tue, 15 January 2008 07:54 Go to previous messageGo to next message
Yeah. You can use the email from above.
Tom
> Tom,
> it seems to work.
> Sebastian
Re: Brainstorming: grid as a spreadsheet [message #46719 is a reply to message #46671] Wed, 16 January 2008 10:58 Go to previous message
Opened an enhancement request.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215504
Sebastian
Re: Brainstorming: grid as a spreadsheet [message #587596 is a reply to message #46350] Fri, 11 January 2008 12:24 Go to previous message
> Hi all,
> Bokowski.
> refresh the viewer
about it.
Tom
Re: Brainstorming: grid as a spreadsheet [message #587627 is a reply to message #46382] Mon, 14 January 2008 03:50 Go to previous message
1)
2)
ViewerCell cell) {
is related.
the current layers.
Sebastian
more :-) .
>> Hi all,
Boris Bokowski.
about it.
> Tom
Re: Brainstorming: grid as a spreadsheet [message #587633 is a reply to message #46470] Mon, 14 January 2008 08:43 Go to previous message
Tom
> 1)
> 2)
> ViewerCell cell) {
> is related.
> the current layers.
> Sebastian
> > Hi,
> more :-) .
> >> Hi all,
> Boris Bokowski.
> about it.
> > Tom
Re: Brainstorming: grid as a spreadsheet [message #587674 is a reply to message #46501] Tue, 15 January 2008 03:57 Go to previous message
Thank you so long.
Sebastian
> Tom
Re: Brainstorming: grid as a spreadsheet [message #587683 is a reply to message #46501] Tue, 15 January 2008 06:20 Go to previous message
Tom,
it seems to work.
Sebastian
Re: Brainstorming: grid as a spreadsheet [message #587690 is a reply to message #46652] Tue, 15 January 2008 07:54 Go to previous message
Tom
> Tom,
> it seems to work.
> Sebastian
Re: Brainstorming: grid as a spreadsheet [message #587721 is a reply to message #46671] Wed, 16 January 2008 10:58 Go to previous message
Sebastian
Previous Topic:Problem with shell closing after the grid drag detection mechanism being enabled and some grid colum
Next Topic:Grid row headers
Current Time: Wed Oct 29 08:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.48172 seconds
