[Validation] Re: java.lang.ClassCircularityError: myPackage/ValidationDelegateClientSelector [message #46297 is a reply to message #46239] |
Mon, 10 December 2007 13:16 |
Hi, Loïc,
This is an EMF Validation Framework question, so I have replied to that
newsgroup.
Are you trying to re-use the client-context defined by the example?
This problem has come up a few times before in the EMF newsgroup, so you
might search for possible solutions (or is that what you meant by "what
[you] have read so far?")
One work-around that I recall having some success is to exclude the package
in which the client-context selector is defined from the lazy-start header
in the bundle manifest.
HTH,
Christian
Loïc Quéran wrote:
> When EMF Validation examples are not loaded, the exception occurs. When
> EMF Validation examples are loaded, the exception does not occur.
> Any idea on the reason for this would be appreciated.
> Eclipse Version: 3.3.0 Build id: I20070621-1340
> Sun JRE 1.6.02
> EMF Validation 1.1.1 200708161445
> What I have read so far on ClassCircularityError seems irrelevant (given
> the previously mentionned version numbers).
> Loïc
-----8<-----
FUDForum. Page generated in 0.02915 seconds
