Home » Modeling » TMF (Xtext) » [XText] problem in importing a metamodel.
[XText] problem in importing a metamodel. [message #46175] Fri, 29 May 2009 06:11 Go to next message
When I use 'import' to import a package, the editor reports the metamodel cannot be resolved. Even though I have copied the metamodel in the same
directory as the grammar, the problem is still there. I do not know why? This may be related to 'classpath' setting, but I have no idea about how to
set class path. Moreover, I would like to import the multiple packages from this metamodel. What can I do about it?
Hints are higly appreaciated.
Cheers
Michael
Re: [XText] problem in importing a metamodel. [message #46268 is a reply to message #46175] Fri, 29 May 2009 08:07 Go to previous messageGo to next message
Hi Michael,
please provide more information (code), so we can see what exactly you
did. I assume that you tried to reference the package via NS-URI.
You should use a platform:/resource URI.
Example:
import "platform:/resource/my.project/model/metamodel.ecore"
If you want to refer to an EPackage in the resource which is not the
first in the root of the resource, you'll have to add the fragment
additionally.
Hope that helps,
Sven
Michael schrieb:
> the same directory as the grammar, the problem is still there. I do not
> about how to set class path. Moreover, I would like to import the
> Cheers
> Michael
Re: [XText] problem in importing a metamodel. [message #46355 is a reply to message #46268] Fri, 29 May 2009 08:32 Go to previous message
Sven Efftinge wrote:
> Hi Michael,
> Example:
> additionally.
> Hope that helps,
> Sven
> Michael schrieb:
>> in the same directory as the grammar, the problem is still there. I do
>> no idea about how to set class path. Moreover, I would like to import
>> Cheers
>> Michael
Hi Sven:
Thanks for your kind help. Now the problem is gone. But now I want to import the packages in the ecore model.
I don't know how to do it. Can you give me quick example?
Cheers.
Michael.
Previous Topic:How to add checks to a grammar?
Next Topic:Cross reference items not available in .chk files
Current Time: Thu Oct 23 01:10:36 EDT 2025
Powered by FUDForum. Page generated in 0.03623 seconds
