Home » Archived » EPF » No tools-section in the published configuration
No tools-section in the published configuration [message #46157] Fri, 30 November 2007 05:24 Go to next message
Hello
I create a new method plugin.
In standard categories\tools i create 2 entries (too1 and tool2).
I create a custom category "tools" where i add these 2 tools.
I crteate a configuration and add the custom category tool.
It correctly shows up as a tabular entry and shows the 2 tools.
When i publish this configuration nothing is shown. The tools section
doesn't show up.
Does this work as designed or is it a bug (in the later case i will post
it to the bugbase) ?
But i'm unshure whether i've seen this functionality in the past (actualy
i believe i did).
Regards Andreas
Re: No tools-section in the published configuration [message #46187 is a reply to message #46157] Fri, 30 November 2007 05:26 Go to previous messageGo to next message
I'm using v1.2.0.2 but had the same problem v1.2.0 and .1
Re: No tools-section in the published configuration [message #46245 is a reply to message #46157] Mon, 03 December 2007 14:15 Go to previous message
Originally posted by: phaumer.us.no-spam.ibm.com
Hello Andreas.
The tools will only be published if there are actually tool mentors written
for it as EPFC does not publish empty categories. All categories in EPFC
will only be published if they are not empty to support the configuration
concept: In other words the rule is that when you remove all elements from
a configuration that have been categorized then the category will also not
be published anymore.
Hope this helps,
Peter.
"Andreas Roehler" <andreas.roehler@barmenia.de> wrote in message
news:46ea44e7195e5a4f0672a4fcdf76094f$1@www.eclipse.org...
> Hello
> doesn't show up.
> i believe i did).
> Regards Andreas
Re: No tools-section in the published configuration [message #585783 is a reply to message #46157] Fri, 30 November 2007 05:26 Go to previous message
Re: No tools-section in the published configuration [message #585807 is a reply to message #46157] Mon, 03 December 2007 14:15 Go to previous message
Hello Andreas.
Hope this helps,
Peter.
> Hello
> doesn't show up.
> i believe i did).
> Regards Andreas
Previous Topic:No tools-section in the published configuration
Next Topic:"Orphaned" Plugin Content
Current Time: Sun Apr 27 01:56:55 EDT 2025
Powered by FUDForum. Page generated in 0.03935 seconds
