Re: No tools-section in the published configuration [message #46245 is a reply to message #46157] |
Mon, 03 December 2007 19:15 |
Originally posted by: phaumer.us.no-spam.ibm.com
Hello Andreas.
The tools will only be published if there are actually tool mentors written
for it as EPFC does not publish empty categories. All categories in EPFC
will only be published if they are not empty to support the configuration
concept: In other words the rule is that when you remove all elements from
a configuration that have been categorized then the category will also not
be published anymore.
Hope this helps,
Peter.
"Andreas Roehler" <andreas.roehler@barmenia.de> wrote in message
news:46ea44e7195e5a4f0672a4fcdf76094f$1@www.eclipse.org...
> Hello
> I create a new method plugin.
> In standard categories\tools i create 2 entries (too1 and tool2).
> I create a custom category "tools" where i add these 2 tools.
> I crteate a configuration and add the custom category tool.
> It correctly shows up as a tabular entry and shows the 2 tools.
> When i publish this configuration nothing is shown. The tools section
> doesn't show up.
> Does this work as designed or is it a bug (in the later case i will post
> it to the bugbase) ?
> But i'm unshure whether i've seen this functionality in the past (actualy
> i believe i did).
> Regards Andreas
FUDForum. Page generated in 0.04106 seconds
