Home » Language IDEs » C / C++ IDE (CDT) » parsing compiler error messages
parsing compiler error messages [message #46136] Mon, 21 October 2002 12:02 Go to next message
Originally posted by: pickens.metaware.com
We're using a different compiler than gcc to do our builds under CDT and
the error messages have a different format. Therefore, I need to be able
to override the error parsing. I noticed that the "ErrorParserManager"
is buried in an internal package, and isn't accessible from an extension
point. Is there a plan to make the error parsing more configurable in
the future?
(I noticed that ErrorParserManager maintains individual IErrorParser
class names from the preference store, but this interface has two
problems: it is an internal interface, and it apparently assumes that
each error message is just one line long.)
- David
Re: parsing compiler error messages [message #46165 is a reply to message #46136] Mon, 21 October 2002 16:30 Go to previous messageGo to next message
I will soon be posting a patch which will basically make ErrorParserManager
and IErrorParser not internal with changes to the manager so that error parsing
is performed inline with the output stream writing.
> the future?
You can get the previous line from ErrorParserManager.getPreviousLine()
Do you require more capabilities from the ErrorParserMananger?
Re: parsing compiler error messages [message #46314 is a reply to message #46165] Tue, 22 October 2002 12:09 Go to previous messageGo to next message
Dave,
Our compiler's error messages can extend for multiple lines after the
source/line marker. It would be nice to capture the entire message for the
Tasks entry. This would require that the error parser be able to consume
multiple lines.
-David
"Dave Inglis" <dinglis@qnx.com> wrote in message
news:3DB463D9.7000208@qnx.com...
ErrorParserManager
parsing
> > the future?
Re: parsing compiler error messages [message #46435 is a reply to message #46314] Tue, 22 October 2002 15:15 Go to previous messageGo to next message
Could your error parser not consume the lines of the message and then add the marker
when it had received all lines?
> Dave,
> multiple lines.
> -David
> ErrorParserManager
> parsing
>>>the future?
Re: parsing compiler error messages [message #46713 is a reply to message #46435] Wed, 23 October 2002 11:25 Go to previous messageGo to next message
Dave,
Yes, I could have "processLine(String line)" track that it is actually in a
multi-line error message and to delay creating the marker until the entire
message is seen.
But it seems like it would be more in the spirit of Eclipse to make error
parsing an extension point with a well-defined interface (e.g.,
IErrorParserManager). Provide a default abstract class that defines
"generateMarker(IResource, line,...)" and "parseOutput(String)" .
parseOutput would create the <name/IFile> map of all files of the workspace
and then call "parse(String)". The default
would read lines and call the abstract method "processLine()" (which is a
protected abstract class that is defined in the abstract class only -- not
the interface). Then ErrorParserManager would be the default concrete
implementation.
This will provide the flexibility for a new plug-in to completely override
"parse(String)" altogether. (Or am I misunderstanding how extension points
work?)
-David
news:3DB5A3DD.4060400@qnx.com...
the marker
> > Dave,
the
> > multiple lines.
> > -David
> > ErrorParserManager
> > parsing
and
able
extension
> >>>the future?
Re: parsing compiler error messages [message #47386 is a reply to message #46713] Thu, 24 October 2002 16:02 Go to previous messageGo to next message
David,
I guess I should have mentioned at the beginning of all this, but the entire
CBuilder will be going through a major change in the near future, at which time
we will most likely provide a means of adding\removing error parsers on a per-project
basis through an extension point, the interface used for this will most likely be
IErrorParser. I have no exact time frame for when this will all take place, but it
should be very soon.
> Dave,
> message is seen.
> implementation.
> work?)
> -David
> the marker
>>>Dave,
> the
>>>multiple lines.
>>>-David
>>>ErrorParserManager
>>>parsing
> and
> able
> extension
>>>>>the future?
Re: parsing compiler error messages [message #47576 is a reply to message #47386] Fri, 25 October 2002 17:46 Go to previous message
That'd be nice although something that didn't require plugin programming,
such as a regular expression in the preferences that recognized the error
that I could edit would be nice too.
news:3DB851EA.9010205@qnx.com...
> David,
entire
time
per-project
likely be
place, but it
Previous Topic:"Outline": parsing problems with wxWindows EVENT_TABLE's
Next Topic:Eclipse & CORBA
Current Time: Tue Jul 01 03:50:20 EDT 2025
Powered by FUDForum. Page generated in 0.33769 seconds
