Home » Archived » M2M (model-to-model transformation) » [ATL] Re: feature e does not exist on
[ATL] Re: feature e does not exist on [message #46058] |
Wed, 13 June 2007 15:08 |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
this usually happens when the helper is not defined, but this is not your case..
Another question, which model handler are you using? AMW or EMF?
Marcos.
ps.: I am copying this message to the ATL newsgroup, maybe somebody can help.
kornev wrote:
> Hi Marcos,
> i am using the ATL launch configuration
> structurebase ->MOF
> IN->AMW
> interbase ->MOF
> advice ->MOF
> structurebase ->structureBase.ecore
> interbase ->interBase.ecore
> advice ->interaction.ecore
> MOF ->#EMF
> IN ->test.ecore
> AMW ->w_model.ecore
> so, structurebase, interbase and advice are metamodels that conform to
> Ecore
> best regards,
> Yuri
> Marcos Didonet Del Fabro schrieb:
>> Hi, how are you executing the transformation? Using the AMW main
>> plug-in or using the ATL launch configuration?
>> Marcos.
>> kornev wrote:
>>> Hi,
>>> i tried to define some transformation rules with Atl and was stumbled
>>> on the following:
>>> (exerpt)
>>> module CPMMWeave;
>>> create OUT : MOF from IN : AMW, interbase: MOF, structurebase: MOF,
>>> advice : MOF;
>>> helper context MOF!EModelElement def: isStBase : Boolean =
>>> MOF!EModelElement.allInstancesFrom ('structurebase')-> exists(e | e =
>>> self );
>>> rule CopyStClass {
>>> from
>>> be : MOF!EClass (be.isStBase)
>>> to
>>> out : MOF!EClass (
>>> name <- be.name,
>>> if i run this littel fragment i get
>>> ****** BEGIN Stack Trace
>>> message: feature isStBase does not exist on interbase!EClass
>>> A.main() : ??#32 null
>>> local variables = {self=CPMMWeave : ASMModule}
>>> local stack = []
>>> A.__matcher__() : ??#1 null
>>> local stack = []
>>> A.__matchCopyBaseInteractionClass() : ??#31 23:34-23:45
>>> local variables = {be=interbase!EClass, self=CPMMWeave : ASMModule}
>>> local stack = []
>>> ****** END Stack Trace
>>> has someone any idea why this is happing,
>>> i run other examples found on the homepage in works fine,
>>> but here i do not understand, why Atl does not recognize that
>>> interbase conforms to the MOF(Ecore) model and cannot apply isStBase
>>> rule?
Re: [ATL] Re: feature e does not exist on [message #46091 is a reply to message #46058] |
Wed, 13 June 2007 15:20 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Could you please try to change your attribute helper to an operation
helper (by adding () after its name in its definition usages). It may
help diagnosing the issue.
Frédéric Jouault
Marcos Didonet Del Fabro wrote:
> Hello,
> your case..
> Marcos.
> help.
> kornev wrote:
>> Hi Marcos,
>> structurebase ->MOF
>> IN->AMW
>> interbase ->MOF
>> advice ->MOF
>> MOF ->#EMF
>> IN ->test.ecore
>> AMW ->w_model.ecore
>> Ecore
>> best regards,
>> Yuri
>>> Marcos.
>>> kornev wrote:
>>>> Hi,
>>>> stumbled on the following:
>>>> (exerpt)
>>>> module CPMMWeave;
>>>> advice : MOF;
>>>> = self );
>>>> rule CopyStClass {
>>>> from
>>>> to
>>>> out : MOF!EClass (
>>>> name <- be.name,
>>>> local stack = []
>>>> local stack = []
>>>> local stack = []
>>>> rule?
Re: [ATL] Re: feature e does not exist on [message #46122 is a reply to message #46058] |
Wed, 13 June 2007 15:40 |
Yury Kornev Messages: 8 Registered: July 2009 |
Junior Member |
i am using EMF model handler
> Hello,
> your case..
> Marcos.
> help.
> kornev wrote:
>> Hi Marcos,
>> structurebase ->MOF
>> IN->AMW
>> interbase ->MOF
>> advice ->MOF
>> MOF ->#EMF
>> IN ->test.ecore
>> AMW ->w_model.ecore
>> Ecore
>> best regards,
>> Yuri
>>> Marcos.
>>> kornev wrote:
>>>> Hi,
>>>> (exerpt)
>>>> module CPMMWeave;
>>>> advice : MOF;
>>>> = self );
>>>> rule CopyStClass {
>>>> from
>>>> to
>>>> out : MOF!EClass (
>>>> name <- be.name,
>>>> local stack = []
>>>> local stack = []
>>>> local stack = []
>>>> rule?
Re: [ATL] Re: feature e does not exist on [message #46152 is a reply to message #46091] |
Wed, 13 June 2007 15:49 |
Junior Member |
Hi Frédéric,
i did how you sad this is the console output
Dumping ASM to C:/workspace/emf/ModeWeaving2/CPMMWeave.asm
message: ERROR: could not find operation isStBase on interbase!EClass
having supertypes: [interbase!EClassifier, OclType, OclAny] (including
Java operations)
A.main() : ??#26 null
local stack = []
local stack = []
A.__matchCopyBaseInteractionClass() : ??#31 23:34-23:47
local stack = []
Execution terminated due to error (see launch configuration to allow
continuation after errors).
Frédéric Jouault schrieb:
> Hello,
> Frédéric Jouault
>> Hello,
>> your case..
>> Regards,
>> Marcos.
>> can help.
>> kornev wrote:
>>> Hi Marcos,
>>> structurebase ->MOF
>>> IN->AMW
>>> interbase ->MOF
>>> advice ->MOF
>>> MOF ->#EMF
>>> IN ->test.ecore
>>> AMW ->w_model.ecore
>>> to Ecore
>>> best regards,
>>> Yuri
>>>> Marcos.
>>>> kornev wrote:
>>>>> Hi,
>>>>> (exerpt)
>>>>> module CPMMWeave;
>>>>> advice : MOF;
>>>>> = self );
>>>>> rule CopyStClass {
>>>>> from
>>>>> to
>>>>> out : MOF!EClass (
>>>>> name <- be.name,
>>>>> local stack = []
>>>>> local stack = []
>>>>> ASMModule}
>>>>> local stack = []
>>>>> isStBase rule?
Re: [ATL] Re: feature e does not exist on [message #46182 is a reply to message #46091] |
Wed, 13 June 2007 15:56 |
Junior Member |
i thought maybe it can be the reason:
in my metamodels one metamodel(structurebase) has references to the
elements of the other one (interbase)?
> Hello,
> Frédéric Jouault
>> Hello,
>> your case..
>> Regards,
>> Marcos.
>> can help.
>> kornev wrote:
>>> Hi Marcos,
>>> structurebase ->MOF
>>> IN->AMW
>>> interbase ->MOF
>>> advice ->MOF
>>> MOF ->#EMF
>>> IN ->test.ecore
>>> AMW ->w_model.ecore
>>> to Ecore
>>> best regards,
>>> Yuri
>>>> Marcos.
>>>> kornev wrote:
>>>>> Hi,
>>>>> (exerpt)
>>>>> module CPMMWeave;
>>>>> advice : MOF;
>>>>> = self );
>>>>> rule CopyStClass {
>>>>> from
>>>>> to
>>>>> out : MOF!EClass (
>>>>> name <- be.name,
>>>>> local stack = []
>>>>> local stack = []
>>>>> ASMModule}
>>>>> local stack = []
>>>>> isStBase rule?
Re: [ATL] Re: feature e does not exist on [message #46242 is a reply to message #46182] |
Wed, 13 June 2007 16:15 |
I do not see where your problem is.
Do you have it committed on some CVS or SVN repository?
Or else, could you package your project (with all necessary files,
including launch configurations or ant scripts) in a zip file?
Frédéric Jouault
>> Hello,
>> Regards,
>> Frédéric Jouault
>>> Hello,
>>> your case..
>>> Regards,
>>> Marcos.
>>> can help.
>>> kornev wrote:
>>>> Hi Marcos,
>>>> structurebase ->MOF
>>>> IN->AMW
>>>> interbase ->MOF
>>>> advice ->MOF
>>>> MOF ->#EMF
>>>> IN ->test.ecore
>>>> AMW ->w_model.ecore
>>>> to Ecore
>>>> best regards,
>>>> Yuri
>>>>> Marcos.
>>>>> kornev wrote:
>>>>>> Hi,
>>>>>> (exerpt)
>>>>>> module CPMMWeave;
>>>>>> MOF, advice : MOF;
>>>>>> e = self );
>>>>>> rule CopyStClass {
>>>>>> from
>>>>>> to
>>>>>> out : MOF!EClass (
>>>>>> name <- be.name,
>>>>>> local stack = []
>>>>>> local stack = []
>>>>>> ASMModule}
>>>>>> local stack = []
>>>>>> isStBase rule?
Re: [ATL] Re: feature e does not exist on [message #46271 is a reply to message #46242] |
Wed, 13 June 2007 18:20 |
Junior Member |
hi Frédéric,
i could localize the place where it does not work for me..
soo the error comes if i use the reference to the EString -Element in
my models (perhaps some other i did not test jet),
this is the example:
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
name="StructureBase"
nsPrefix="">
<eClassifiers xsi:type="ecore:EClass" name="Cl">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
but if i create my own datatype String instead of using the EString of
Ecore in the main package, the model is transformed without any errors.
Is it a limitation in ATL or is something wrong with my settings?
best regards,
yuri
> Hello,
> Best regards,
> Frédéric Jouault
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>>> Hello,
>>>> your case..
>>>> Regards,
>>>> Marcos.
>>>> can help.
>>>> kornev wrote:
>>>>> Hi Marcos,
>>>>> structurebase ->MOF
>>>>> IN->AMW
>>>>> interbase ->MOF
>>>>> advice ->MOF
>>>>> MOF ->#EMF
>>>>> IN ->test.ecore
>>>>> AMW ->w_model.ecore
>>>>> to Ecore
>>>>> best regards,
>>>>> Yuri
>>>>>> Marcos.
>>>>>> kornev wrote:
>>>>>>> Hi,
>>>>>>> (exerpt)
>>>>>>> module CPMMWeave;
>>>>>>> MOF, advice : MOF;
>>>>>>> e = self );
>>>>>>> rule CopyStClass {
>>>>>>> from
>>>>>>> to
>>>>>>> out : MOF!EClass (
>>>>>>> name <- be.name,
>>>>>>> local stack = []
>>>>>>> local stack = []
>>>>>>> ASMModule}
>>>>>>> local stack = []
>>>>>>> isStBase rule?
Re: [ATL] Re: feature e does not exist on [message #47462 is a reply to message #46331] |
Tue, 19 June 2007 11:19 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
I cannot reproduce this issue. I use ATL on a similar metamodel without
issues:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML2CaseStudies/uml 2cs-instantmessenger-config/model/InstantMessenger.ecore?vie w=markup
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML2CaseStudies/uml 2cs-instantmessenger-config-editor/src/be/ac/vub/uml2cs/inst antmessenger/popup/actions/GenerateBuildFileAction.java?view =markup
If you still experience this issue, please file a bug report:
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced&product=M2M
Also include the files necessary to reproduce the problem.
Dennis
kornev schreef:
> i'll do it, thanks you and Marcos for help.
> regards,
> yuri
>> Hello,
>> > <?xml version="1.0" encoding="UTF-8"?>
>> > xmlns:xmi="http://www.omg.org/XMI"
>> > nsPrefix="">
>> > </eClassifiers>
>> > </ecore:EPackage>
>> errors.
>> ATL should be able to work with this, but you may have found a bug.
>> Could you please create a bugzilla entry for it?
>> Thanks.
>> Regards,
>> Frédéric Jouault
Re: [ATL] Re: feature e does not exist on [message #54879 is a reply to message #47462] |
Thu, 26 July 2007 11:36 |
Junior Member |
hi,
so i got this response
------- Comment #1 from mikael.barbero@univ-nantes.fr 2007-06-18 05:18
Dear Yuri,
Using Ecore datatypes (i.e. datatypes defined in the metametamodel --
M3) in a
metamodel -- M2 is not very clean from our point of view. The fact you reuse
something from the M3 level can be seen as a re-definition of this M3
level. It
doesn't stick with the modeling base principles. Then, we don't planned to
solve this "bug".
> issues:
> Dennis
> kornev schreef:
>> regards,
>> yuri
>>> Hello,
>>> -Element in
>>> > nsPrefix="">
>>> > </eClassifiers>
>>> > </ecore:EPackage>
>>> EString of
>>> errors.
>>> Thanks.
>>> Regards,
>>> Frédéric Jouault
Re: [ATL] Re: feature e does not exist on [message #54960 is a reply to message #54879] |
Thu, 26 July 2007 12:30 |
kornev schreef:
> hi,
Ok, I have some food for thought on that one ;-).
> Dear Yuri,
> M3) in a
> reuse
> level. It
> solve this "bug".
I do not agree ;-)). Using the Ecore *language* can be done on any
M-level. If I import the Ecore language as part of my own language, then
that has no effect on the M-level.
I use strings in my meta-model as well as in my model, and the semantics
of "string" is the same for both M-levels. Hence, I can use the same
language construct (from the same language). UML goes even further in
its reuse of Ecore constructs and makes it possible to add EAnnotations
to all UML elements.
Dennis
>> without issues:
>> Regards,
>> Dennis
>> kornev schreef:
>>> Hi,
>>> regards,
>>> yuri
>>>> Hello,
>>>> -Element in
>>>> > nsPrefix="">
>>>> > </eClassifiers>
>>>> > </ecore:EPackage>
>>>> EString of
>>>> errors.
>>>> Thanks.
>>>> Regards,
>>>> Frédéric Jouault
Current Time: Wed Jan 15 13:50:03 GMT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
