Home » Modeling » TMF (Xtext) » [XText] newbie question: Can XText generate code.
[XText] newbie question: Can XText generate code. [message #45850] |
Thu, 28 May 2009 09:55  |
I am a newbie of XText. So far, I have known that XText can be used to generate parsers and language editors. However I am wondering whether XText can be used to
generate code, and how. In fact, I did not find any Java class is intended for generating code in a built-in example XText project. Hints are welcome.
Thanks.
Michael
Re: [XText] newbie question: Can XText generate code. [message #45998 is a reply to message #45850] |
Fri, 29 May 2009 01:42   |
Hi Michael,
Xtext is a framework that helps you to create textual domain specific
languages and appropriate tooling for them. Keeping that in mind, I
won't say Xtext is a classic code generator. But you may use it to store
a semantic model in a concrete textual syntax (generate something). With
the help of the generated parser, these text files can be loaded back
into memory. During the loading process Xtext will recreate your
semantic model.
That said, you can do some kind of roundtrip engineering with Xtext:
Text -[parsing/loading]->
Model -[in memory modification aka transformation, refactoring ..]->
Model -[serialization]->
Text ...
Doesn't look like the classic code generator usecase, does it?
Please describe in a few words what you are trying to achieve.
Sebastian
Am 28.05.2009 15:55 Uhr, schrieb Michael:
> are welcome.
> Thanks.
> Regards
> Michael
Re: [XText] newbie question: Can XText generate code. [message #47289 is a reply to message #47213] |
Tue, 02 June 2009 14:25   |
Hi Steven,
I'm not sure what you mean but if you're talking of serializing a parsed
model back to its textual representation, I can say that it's hard
generate such a serializer from a grammar.
I know this because we've had (actually Moritz Eysholdt had) hard time
to solve this. But it is solved and with TMF Xtext you get this
serialization mechanism generated for your grammar. :-)
But I bet you knew that already and I completely missed the point...
Sven
Steven Derrien schrieb:
> Just a very naive question : how difficult would it be to automatically
> generate a xpand template that would map a model onto a textual
> representation generated according to the xtext grammar (a kind of
> source to source workflow)?
> Steven
> Sven Efftinge a écrit :
>> Hi Steffen,
>> sure, I just wanted to clarify in order to avoid confusing other
>> people, who don't have the oAW background but are looking at the stuff
>> from the Eclipse-point of view, where the components live in different
>> projects.
>> Cheers,
>> Sven
>> Steffen Stundzig schrieb:
>>> Sven Efftinge wrote:
>>>> The code generation technology is called Xpand (M2T Xpand).
>>>> MWE is just a tool to orchestrate and configure things like code
>>>> generators, model parsers and model transformations.
>>> thx for the clarification again. In my simple _obsolete_ world, there
>>> exists only the two components xtext and oaw in mind. ;)
>>> regards
>>> Steffen...
Re: [XText] newbie question: Can XText generate code. [message #47363 is a reply to message #47289] |
Tue, 02 June 2009 17:00   |
> Hi Steven,
No you did not, I didn't know that this feature was available in xtext.
Is it documented somewhre, are there some examples ?
It seems that it's me who completely missed the point ...
Steven
> Cheers,
> Sven
>> automatically generate a xpand template that would map a model onto a
>> textual representation generated according to the xtext grammar (a
>> kind of source to source workflow)?
>> Steven
>>> Hi Steffen,
>>> stuff from the Eclipse-point of view, where the components live in
>>> different projects.
>>> Cheers,
>>> Sven
>>>> there exists only the two components xtext and oaw in mind. ;)
>>>> regards
>>>> Steffen...
Re: [XText] newbie question: Can XText generate code. [message #47453 is a reply to message #47363] |
Wed, 03 June 2009 05:46  |
The serialization and pretty printing is not yet documented.
But we'll add it to the documentation within the next weeks (i.e. will
be documented in the Galileo release which is due June 24th).
Sven
Current Time: Wed Apr 16 14:29:07 EDT 2025
Powered by FUDForum. Page generated in 0.04372 seconds
