Home » Modeling » TMF (Xtext) » [XText] newbie question: Can XText generate code.
- [XText] newbie question: Can XText generate code. [message #45850] Thu, 28 May 2009 09:55 Go to next message
I am a newbie of XText. So far, I have known that XText can be used to generate parsers and language editors. However I am wondering whether XText can be used to
generate code, and how. In fact, I did not find any Java class is intended for generating code in a built-in example XText project. Hints are welcome.
Thanks.
Michael
- Re: [XText] newbie question: Can XText generate code. [message #45998 is a reply to message #45850] Fri, 29 May 2009 01:42 Go to previous messageGo to next message
Hi Michael,
Xtext is a framework that helps you to create textual domain specific
languages and appropriate tooling for them. Keeping that in mind, I
won't say Xtext is a classic code generator. But you may use it to store
a semantic model in a concrete textual syntax (generate something). With
the help of the generated parser, these text files can be loaded back
into memory. During the loading process Xtext will recreate your
semantic model.
That said, you can do some kind of roundtrip engineering with Xtext:
Text -[parsing/loading]->
Model -[in memory modification aka transformation, refactoring ..]->
Model -[serialization]->
Text ...
Doesn't look like the classic code generator usecase, does it?
Please describe in a few words what you are trying to achieve.
Sebastian
Am 28.05.2009 15:55 Uhr, schrieb Michael:
> are welcome.
> Thanks.
> Regards
> Michael
- Re: [XText] newbie question: Can XText generate code. [message #46057 is a reply to message #45850] Fri, 29 May 2009 02:57 Go to previous messageGo to next message
Hi Michael,
if you use the "New Project/Xtext Project"-Wizard, you got a generator
project in your workspace. In this generator project you could find a
sample model and sample templates (xpand) to generate some sample code
with the modeling workflow engine (openArchitectureWare).
Xtext is the tool to build editors, mwe(oaw) is the tool to generate code
from models created with your own Xtext editor.
hth.
regards
Michael wrote:
can be used to
> Thanks.
> Regards
> Michael
- Re: [XText] newbie question: Can XText generate code. [message #46086 is a reply to message #46057] Fri, 29 May 2009 03:27 Go to previous messageGo to next message
Steffen Stundzig schrieb:
> Hi Michael,
> code from models created with your own Xtext editor.
> hth.
The code generation technology is called Xpand (M2T Xpand).
MWE is just a tool to orchestrate and configure things like code
generators, model parsers and model transformations.
Sven
- Re: [XText] newbie question: Can XText generate code. [message #47038 is a reply to message #46086] Tue, 02 June 2009 04:52 Go to previous messageGo to next message
thx for the clarification again. In my simple _obsolete_ world, there
exists only the two components xtext and oaw in mind. ;)
regards
Steffen...
- Re: [XText] newbie question: Can XText generate code. [message #47068 is a reply to message #47038] Tue, 02 June 2009 09:15 Go to previous messageGo to next message
Hi Steffen,
sure, I just wanted to clarify in order to avoid confusing other people,
who don't have the oAW background but are looking at the stuff from the
Eclipse-point of view, where the components live in different projects.
Sven
> regards
> Steffen...
- Re: [XText] newbie question: Can XText generate code. [message #47213 is a reply to message #47068] Tue, 02 June 2009 10:24 Go to previous messageGo to next message
Originally posted by: sderrienREMOVE.irisa.fr
Just a very naive question : how difficult would it be to automatically
generate a xpand template that would map a model onto a textual
representation generated according to the xtext grammar (a kind of
source to source workflow)?
Steven
Sven Efftinge a écrit :
> Hi Steffen,
> Cheers,
> Sven
>> regards
>> Steffen...
- Re: [XText] newbie question: Can XText generate code. [message #47289 is a reply to message #47213] Tue, 02 June 2009 14:25 Go to previous messageGo to next message
Hi Steven,
I'm not sure what you mean but if you're talking of serializing a parsed
model back to its textual representation, I can say that it's hard
generate such a serializer from a grammar.
I know this because we've had (actually Moritz Eysholdt had) hard time
to solve this. But it is solved and with TMF Xtext you get this
serialization mechanism generated for your grammar. :-)
But I bet you knew that already and I completely missed the point...
Sven
Steven Derrien schrieb:
> Steven
>> Hi Steffen,
>> people, who don't have the oAW background but are looking at the stuff
>> from the Eclipse-point of view, where the components live in different
>> projects.
>> Cheers,
>> Sven
>>> regards
>>> Steffen...
- Re: [XText] newbie question: Can XText generate code. [message #47363 is a reply to message #47289] Tue, 02 June 2009 17:00 Go to previous messageGo to next message
> Hi Steven,
No you did not, I didn't know that this feature was available in xtext.
Is it documented somewhre, are there some examples ?
It seems that it's me who completely missed the point ...
Steven
> Cheers,
> Sven
>> automatically generate a xpand template that would map a model onto a
>> textual representation generated according to the xtext grammar (a
>> kind of source to source workflow)?
>> Steven
>>> Hi Steffen,
>>> stuff from the Eclipse-point of view, where the components live in
>>> different projects.
>>> Cheers,
>>> Sven
>>>> there exists only the two components xtext and oaw in mind. ;)
>>>> regards
>>>> Steffen...
- Re: [XText] newbie question: Can XText generate code. [message #47453 is a reply to message #47363] Wed, 03 June 2009 05:46 Go to previous message
The serialization and pretty printing is not yet documented.
But we'll add it to the documentation within the next weeks (i.e. will
be documented in the Galileo release which is due June 24th).
Sven
Previous Topic:[Announce] TMF XTEXT 0.7.0RC3 is available
Next Topic:[Xtext] Using Eclipse Modeling tools download for Galileo RC2
Current Time: Sun Apr 27 19:59:35 EDT 2025
Powered by FUDForum. Page generated in 0.04254 seconds
