| extending eclipse class loaders [message #45653] | Tue, 21 September 2004 04:52  |  |
| Eclipse User  |  |  |  |  | Originally posted by: stepper.sympedia.com
 hi,
 there have been some older postings that might cover the same
 topic, but those guys seemed to already have a better understanding
 of eclipse class loading. my understanding is more basic...
 does anybody know, if it is possible to change the class
 that is used as plugin classloader, either for all plugins or
 better for certain plugins?
 i don't want to change the loader-hierarchy or the strategy.
 it would be great, to substitute a classloader, that is, for
 example, able to load encrypted jars to enforce a license...
 cheers
 /eike
| Re: extending eclipse class loaders [message #45684 is a reply to message #45653] | Tue, 21 September 2004 16:57  |  |
| Eclipse User  |  |  |  |  | Hi,
 the new OSGi-based runtime and its adoption in Eclipse 3.0 indeed allows
 you to do that. I did this to integrate load-time bytecode modification
 into the runtime (for load-time aspect weaving).
 What you need to do is:
 - Implement your own framework adaptor for example as a subclass of
 org.eclipse.core.runtime.adaptor.EclipseAdaptor. Using your subclass you
 can override "getElementFactory" to return a specialized factory for
 framework elements. This specialized element factory can, for example,
 subclass org.eclipse.core.runtime.adaptor.EclipseElementFactory and
 override the method "createClassLoader". This method is used by the
 runtime to create class loaders for bundles (plugins). You can get
 information about the bundle for which the class loader should be
 created from the parameters of that method (if you would like to create
 different kinds of class loaders for different bunldes/plugins).
 - You can implement your specialized class loader as a subclass of
 org.eclipse.core.runtime.adaptor.EclipseClassLoader (by overriding
 "findClassImpl").
 - Now you need tell your runtime to use your specialized adaptor instead
 of the EclipseAdaptor and your plugin (that contains your specialized
 class loader and your specialized framework adaptor) needs to provide a
 spezialized ADAPTOR.MF file. You can find many interesting information
 on this in the comments of this bug:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=48695
 Hope this helps to provide a first insight.
 If you want to take a look at an example you can download the current
 release candidate of AJEER (AspectJ-Enabled Eclipse Runtime) from my
 website (http://www.martinlippert.com). Take a look at the
 org.eclipse.transformer plugin. There you should find everything you
 need to get a first impression. (The current version works well with M9
 and with some modified startup options also with R3.0. Haven't put up
 the newest version yet.)
 Let me know if you need more help with this.
 Martin
 Eike Stepper wrote:
 > hi,
 > cheers
 > /eike
FUDForum. Page generated in 0.03859 seconds
