Home » Archived » M2M (model-to-model transformation) » Where to get source code of ATL?
Where to get source code of ATL? [message #45652] Wed, 13 June 2007 03:02 Go to next message
stephen Yu is currently offline stephen YuFriend
Member
Are ATL plugins open source, right? Currently, I'm working on Model
transformation based on ATL.Would you tell me where to get the source code
for ATL related plugins?
I need source code for following plugins:
org.atl.eclipse.adt.builder
org.atl.eclipse.adt.debug
org.atl.eclipse.adt.doc.developer
org.atl.eclipse.adt.doc.user
org.atl.eclipse.adt.editor
org.atl.eclipse.adt.perspective
org.atl.eclipse.adt.wizard
org.atl.eclipse.engine
org.atl.eclipse.km3
org.atl.engine.repositories.emf4atl
org.atl.engine.repositories.mdr4atl
org.atl.engine.vm
org.eclipse.am3.core
org.eclipse.am3.tools.tge
org.eclipse.am3.ui
Thanks a lot
Stephen
Re: [ATL] Where to get source code of ATL? [message #45715 is a reply to message #45652] Wed, 13 June 2007 06:07 Go to previous messageGo to next message
Frédéric Jouault is currently offline Frédéric JouaultFriend
Could you please prefix the subject of your ATL-related posts to this
newsgroup with [ATL], as I did in this reply? Thanks.
You can get the source of ATL the same way you get the source of every
other Eclipse project: on the Eclipse CVS. The parameters for ATL are:
Server: dev.eclipse.org
Repository: /cvsroot/modeling
Path: org.eclipse.m2m/org.eclipse.m2m.atl
There is also a link to browse the CVS at the bottom of the ATL page
(http://www.eclipse.org/m2m/atl/):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/?root=Modeling_Project
Frédéric Jouault
Stephen Yu wrote:
> code for ATL related plugins?
> org.atl.eclipse.adt.builder org.atl.eclipse.adt.debug
> org.atl.eclipse.adt.doc.developer org.atl.eclipse.adt.doc.user
> org.atl.eclipse.adt.editor org.atl.eclipse.adt.perspective
> org.atl.eclipse.adt.wizard org.atl.eclipse.engine org.atl.eclipse.km3
> org.atl.engine.repositories.emf4atl org.atl.engine.repositories.mdr4atl
> org.atl.engine.vm org.eclipse.am3.core org.eclipse.am3.tools.tge
> org.eclipse.am3.ui
> Thanks a lot
> Stephen
Re: [ATL] Where to get source code of ATL? [message #45745 is a reply to message #45715] Wed, 13 June 2007 06:38 Go to previous messageGo to next message
Member
Hi Frédéric,
Thanks for your reminder. However, I'm talking about the source code for
Build February 16, 2007 [the file I downloaded is
atl_am3-stable.zip.See:http://www.eclipse.org/m2m/atl/downlo ad/]
Just as you mentioned, I check out the source code from CVS, but they are
not the source code for the build Build February 16, 2007.
In addition, some source code are not found in
[ http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/?root=Modeling_Project],
for example org.atl.eclipse.km3 is not there, where to get its source code?
Thanks a lot.
Stephen Yu.
Frédéric Jouault wrote:
> Hello,
> Frédéric Jouault
> Stephen Yu wrote:
>> org.eclipse.am3.ui
>> Thanks a lot
>> Stephen
Re: [ATL] Where to get source code of ATL? [message #45775 is a reply to message #45745] Wed, 13 June 2007 06:55 Go to previous messageGo to next message
CVS keeps the history of everything that happened. If you want the
source code for a given date, just ask ;-).
Note that if the date you are interested in is before the migration of
ATL from GMT to M2M you have to use the GMT CVS:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/ATL /?root=Technology_Project
The KM3 plugin did not follow the migration of ATL from GMT to M2M, and
is now in AM3 (see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /?root=Technology_Project).
Frédéric Jouault
Stephen Yu wrote:
> Hi Frédéric,
> are not the source code for the build Build February 16, 2007.
> Thanks a lot.
> Stephen Yu.
>> Hello,
>> Regards,
>> Frédéric Jouault
>> Stephen Yu wrote:
>>> Hi,
>>> org.atl.engine.repositories.mdr4atl org.atl.engine.vm
>>> org.eclipse.am3.ui
>>> Thanks a lot
>>> Stephen
Re: [ATL] Where to get source code of ATL? [message #45807 is a reply to message #45775] Wed, 13 June 2007 07:41 Go to previous messageGo to next message
Member
I got all the source code now. Thank you so much!
Stephen
> Hello,
> is now in AM3 (see
> Frédéric Jouault
> Stephen Yu wrote:
>> Hi Frédéric,
>> Thanks a lot.
>> Stephen Yu.
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>> Stephen Yu wrote:
>>>> Hi,
>>>> org.eclipse.am3.ui
>>>> Thanks a lot
>>>> Stephen
Re: [ATL] Where to get source code of ATL? [message #47010 is a reply to message #45775] Sat, 16 June 2007 16:17 Go to previous messageGo to next message
Jens von Pilgrim is currently offline Jens von PilgrimFriend
On 2007-06-13 08:55:45 +0200, Frédéric Jouault
Is
it possible to add this link (or the CVS settings) to the download
page, since this repository is needed to load the sources of the last
stable version? I've also searched this URL some days ago and it took
me some time to find it...
Jens
Re: [ATL] Where to get source code of ATL? [message #47981 is a reply to message #47010] Thu, 21 June 2007 11:50 Go to previous message
> Is
> it possible to add this link (or the CVS settings) to the download page,
> since this repository is needed to load the sources of the last stable
> version? I've also searched this URL some days ago and it took me some
> time to find it...
Yes, it is possible. However, I believe it would also fit quite well on
the wiki (e.g., on page http://wiki.eclipse.org/index.php/ATL). Please,
feel free to add the link there ;-).
Frédéric Jouault
Previous Topic:[ATL]about "inject XML file to XML model(Ecore based)"
Next Topic:[ATL] non deterministic behaivor
Current Time: Mon Dec 30 16:35:19 GMT 2024
Powered by FUDForum. Page generated in 0.04060 seconds
