Re: Lastest AJDT with older versions of AspectJ? [message #45668 is a reply to message #45638] |
Fri, 07 January 2005 15:34 |
Originally posted by: clemas.uk.ibm.com
Scott Delap wrote:
> Is it possible to use the lastest versions of AJDT with older versions
> of AspectJ? I'm on a project that uses an older version of AspectJ with
> a few modifications added in. However, I'd like to use Eclipse 3.1M4 as
> my IDE. This would require the latest version of AJDT.
> Scott
Unfortunately, I don't think it will be possible. We have been making
changes in the interfaces between AspectJ and AJDT to give better
integration and your older AspectJ won't have those changes in.
It is *possible*, depending on where your changes are, that you could
patch up the aspectj (with a jar -uvf) in AJDT to include them but I'd
need more details on what your modifications are to confirm whether it
is worth trying that.
AJDT for 3.1M4 uses the recent AspectJ 1.5.0M1 build. How old is the
AspectJ you are using? Is it a modified 1.2.1?
cheers,
Andy.
Andy Clement
AspectJ Committer
FUDForum. Page generated in 0.03808 seconds
