Home » Language IDEs » PHP Development Tools (PDT) » where is PHP perspective?
where is PHP perspective? [message #45594] Thu, 23 August 2007 11:28 Go to next message
Originally posted by: ced#morteachispamma#.comu.riccio.it
hi all,
I would like to try PDT.
Downloaded "pdt-all-in-one-incubation-S20070815_M2-win32.zip" unzipped
in c:\ on my winxp sp2.
in help file i have found
Click the select Perspective icon at the top right of the window.
Select Other from the drop down list. The Select Perspective dialog will
open.
Select PHP and click OK.
But I don't have any PHP to select!!!
can you help me?
Re: where is PHP perspective? [message #45657 is a reply to message #45594] Thu, 23 August 2007 12:25 Go to previous messageGo to next message
Originally posted by: pobox.verysmall.org
Hi Marco,
I did it this way -
* download, unzip and run Eclipse Europa (3.3)
* Add PDT to the Eclipse Updater -
http://download.eclipse.org/tools/php/updates/, expand the Europa
Discovery site and click Select Required
Then everything was in place.
Iavor
Marco wrote:
> hi all,
> open.
> can you help me?
Re: where is PHP perspective? [message #45687 is a reply to message #45657] Thu, 23 August 2007 13:07 Go to previous messageGo to next message
Thank's Iavor
I need a little more help...
to add PDT to the eclipse update i do:
help->software update->find & install->search new feature then add
remote site and use the url you give me.
but i can't understand wath expand europa ... mean :-(
Marco.
Iavor Raytchev ha scritto:
> Hi Marco,
> I did it this way -
> Iavor
Re: where is PHP perspective? [message #45806 is a reply to message #45687] Thu, 23 August 2007 13:54 Go to previous messageGo to next message
Originally posted by: ganoro.gmail.com
don't forget that PDT requires -
Java 1.5
Eclipse SDK v3.3 version
EMF SDO XSD 2.3.0 SDK version
GEF 3.3 SDK version
DTP 1.5 SDK version
WTP 2.0 SDK version
if you experience difficulties take the all-in-one package.
Re: where is PHP perspective? [message #46077 is a reply to message #45806] Fri, 24 August 2007 07:12 Go to previous messageGo to next message
Roy Ganor ha scritto:
> don't forget that PDT requires - Java 1.5 Eclipse SDK v3.3 version EMF
> SDO XSD 2.3.0 SDK version GEF 3.3 SDK version DTP 1.5 SDK version WTP
> 2.0 SDK version
Thank's Roy,
My first, unsuccessfully, attempt was with the all-in-one package!
at this url
" http://download.eclipse.org/tools/pdt/downloads/?release=S20 070815-M2"
i've found:
- EMF SDO XSD 2.3.0 SDK version
- GEF 3.3 SDK version
- DTP 1.5 SDK version
- WTP 2.0 SDK version
but the links associated are broken!
I will try some search...
Re: where is PHP perspective? [message #46109 is a reply to message #46077] Fri, 24 August 2007 07:22 Go to previous messageGo to next message
Emil Ivanov is currently offline Emil IvanovFriend
>> EMF SDO XSD 2.3.0 SDK version GEF 3.3 SDK version DTP 1.5 SDK version
>> WTP 2.0 SDK version
> Thank's Roy,
> at this url
> i've found:
I had a similar problem. Mine was that the java I was using was 1.4.2.
Now I'm running 1.6 and it works fine (although 1.5 is the official
required version).
Try java -version to see what version of java you are using.
Emil Ivanov
Re: where is PHP perspective? [message #46169 is a reply to message #46077] Fri, 24 August 2007 07:43 Go to previous messageGo to next message
>> WTP 2.0 SDK version
> Thank's Roy,
> at this url
> i've found:
A desperate try...
unzipped the all-in-one over the eclipse europa 3.3 foldere (with
overwrite no)
But nothing changed :-(
Re: where is PHP perspective? [message #46198 is a reply to message #46109] Fri, 24 August 2007 07:44 Go to previous messageGo to next message
> required version).
> Emil Ivanov
GREAT!!!
With the Java -version i could see that Oracle client java 1.4.2 whas
the active java!
Changed the path to get 1.5
Now I can see the php perspective!
Thank's to all
Re: where is PHP perspective? [message #49561 is a reply to message #46169] Thu, 06 September 2007 21:15 Go to previous message
Originally posted by: codeslave.ca.ibm.com
Overwrite=no probably prevented the plugins/ and features/ folders from
being updated w/ the new content.
Suggest getting the all-in-one and unpack it into a new folder.
Nick Boldt
http://divbyzero.com
>>> WTP 2.0 SDK version
>> Thank's Roy,
>> at this url
>> i've found:
> A desperate try...
> overwrite no)
Previous Topic:Posted a couple of debug bugs/enancements
Next Topic:Extensions and code assist
Current Time: Sat Dec 21 14:45:23 GMT 2024
Powered by FUDForum. Page generated in 0.03502 seconds
