Home » Archived » M2M (model-to-model transformation) » Metamodel UML2
Metamodel UML2 [message #45503] Mon, 11 June 2007 08:38 Go to next message
Originally posted by: bch.openbluelab.org
Do you know where the metamodel UML2 is available ?
Re: Metamodel UML2 [message #45536 is a reply to message #45503] Mon, 11 June 2007 09:21 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Benjamin CHEVALLEREAU a écrit :
Hi Benjamin,
The UML2 metamodel is available from the Eclipse UML2 plugin:
http://www.eclipse.org/modeling/mdt/?project=uml2
For using this metamodel in ATL, you have to install the UML2 plugins
and to specifiy the metamodel by URI in your launch configuration or ANT
script: http://www.eclipse.org/uml2/2.0.0/UML
> Thanks
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: Metamodel UML2 [message #45564 is a reply to message #45536] Mon, 11 June 2007 09:49 Go to previous messageGo to next message
Do you know an other transformation using UML2 to help me ?
> Hi Benjamin,
>> Thanks
> Best regards,
> Hugo
Re: Metamodel UML2 [message #46543 is a reply to message #45564] Thu, 14 June 2007 14:24 Go to previous messageGo to next message
I have made all my transformation except Stereotype. Apparently, in
UML2, stereotypes are stored in a profile in an other file. So, how can
create my transformation to get my 2 files and to link its ?
> Thanks
>>> Hi,
>> Hi Benjamin,
>> ANT script: http://www.eclipse.org/uml2/2.0.0/UML
>>> Thanks
>> Best regards,
>> Hugo
Re: Metamodel UML2 [message #46597 is a reply to message #46543] Thu, 14 June 2007 15:42 Go to previous messageGo to next message
--------------040508040206040300090904
Hi Benjamin,
Re: Metamodel UML2 [message #46660 is a reply to message #46597] Fri, 15 June 2007 07:45 Go to previous messageGo to next message
Thanks to send me this files but do you know where I can find metamodel ?
Best regards
> Hi Benjamin,
>> can create my transformation to get my 2 files and to link its ?
> You can find in the attached files an example of a transformation using
> profiles and the corresponding launch configuration.
> Hugo
>> Thanks
>>> Thanks
>>>>> Hi,
>>>> Hi Benjamin,
>>>> plugins and to specifiy the metamodel by URI in your launch
>>>> configuration or ANT script: http://www.eclipse.org/uml2/2.0.0/UML
>>>>> Thanks
>>>> Best regards,
>>>> Hugo
[ATL] Re: Metamodel UML2 [message #46677 is a reply to message #46660] Fri, 15 June 2007 08:21 Go to previous message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Benjamin,
The UML2 metamodel is available here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.uml2/plugins/org.eclipse.uml2.uml/model/?root=Model ing_Project
Freddy.
> Hi
> Best regards
>> Hi Benjamin,
>>> Hi,
>> using profiles and the corresponding launch configuration.
>> Hugo
>>> Thanks
>>>> Thanks
>>>>>> Hi,
>>>>> Hi Benjamin,
>>>>>> Thanks
>>>>> Best regards,
>>>>> Hugo
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Previous Topic:[ATL] execution different between "plugin" and standalone
Next Topic:[ATL] Can't use getOpposite on UML!Property
Current Time: Sat Dec 21 15:10:01 GMT 2024
Powered by FUDForum. Page generated in 0.14655 seconds
