Metamodel UML2 [message #45503] |
Mon, 11 June 2007 08:38 |
Originally posted by: bch.openbluelab.org
Do you know where the metamodel UML2 is available ?
Re: Metamodel UML2 [message #45564 is a reply to message #45536] |
Mon, 11 June 2007 09:49 |
Do you know an other transformation using UML2 to help me ?
Hugo Bruneliere a écrit :
> Benjamin CHEVALLEREAU a écrit :
> Hi Benjamin,
> The UML2 metamodel is available from the Eclipse UML2 plugin:
> http://www.eclipse.org/modeling/mdt/?project=uml2
> For using this metamodel in ATL, you have to install the UML2 plugins
> and to specifiy the metamodel by URI in your launch configuration or ANT
> script: http://www.eclipse.org/uml2/2.0.0/UML
>> Thanks
> Best regards,
> Hugo
Re: Metamodel UML2 [message #46543 is a reply to message #45564] |
Thu, 14 June 2007 14:24 |
I have made all my transformation except Stereotype. Apparently, in
UML2, stereotypes are stored in a profile in an other file. So, how can
create my transformation to get my 2 files and to link its ?
> Thanks
>>> Hi,
>> Hi Benjamin,
>> ANT script: http://www.eclipse.org/uml2/2.0.0/UML
>>> Thanks
>> Best regards,
>> Hugo
Re: Metamodel UML2 [message #46597 is a reply to message #46543] |
Thu, 14 June 2007 15:42 |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
--------------040508040206040300090904
Hi Benjamin,
Re: Metamodel UML2 [message #46660 is a reply to message #46597] |
Fri, 15 June 2007 07:45 |
Thanks to send me this files but do you know where I can find metamodel ?
Best regards
> Hi Benjamin,
>> can create my transformation to get my 2 files and to link its ?
> You can find in the attached files an example of a transformation using
> profiles and the corresponding launch configuration.
> Hugo
>> Thanks
>>> Thanks
>>>>> Hi,
>>>> Hi Benjamin,
>>>> plugins and to specifiy the metamodel by URI in your launch
>>>> configuration or ANT script: http://www.eclipse.org/uml2/2.0.0/UML
>>>>> Thanks
>>>> Best regards,
>>>> Hugo
[ATL] Re: Metamodel UML2 [message #46677 is a reply to message #46660] |
Fri, 15 June 2007 08:21 |
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Benjamin,
The UML2 metamodel is available here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.uml2/plugins/org.eclipse.uml2.uml/model/?root=Model ing_Project
Freddy.
> Hi
> Best regards
>> Hi Benjamin,
>>> Hi,
>> using profiles and the corresponding launch configuration.
>> Hugo
>>> Thanks
>>>> Thanks
>>>>>> Hi,
>>>>> Hi Benjamin,
>>>>>> Thanks
>>>>> Best regards,
>>>>> Hugo
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
FUDForum. Page generated in 0.03992 seconds
