Home » Eclipse Projects » Nebula » Column layout for Grid similar to TableColumnLayout?
Column layout for Grid similar to TableColumnLayout? [message #45495] Mon, 07 January 2008 19:19 Go to next message
Ryan Norris is currently offline Ryan NorrisFriend
I've been using the JFace TableViewer and have recently switched to
GridTableViewer. JFace provides TableLayout and TableColumnLayout for
positioning the columns of a table widget using pixel-based and weight-based
column data objects. After I switched to GridTableViewer, I can no longer
use either of these because they are specific to the Table widget.
Are there any plans to provide a layout for the Grid widget that uses
ColumnLayoutData objects?
I looked at creating a GridColumnLayout similar to TableColumnLayout
unfortunately the base class, org.eclipse.jface.layout.AbstractColumnLayout,
and its abstract methods are all package scope and therefore inaccessible.
If this class and its abstract methods were public, a Grid-specific version
could be contributed to and included with the Grid viewer classes.
-Ryan Norris
Re: Column layout for Grid similar to TableColumnLayout? [message #45525 is a reply to message #45495] Mon, 07 January 2008 19:24 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
File a bug against Platform/UI and ask for opening up the API. In the
meanwhile and not to put dependencies on JFace 3.4 you could copy those
classes, I'd suggest.
Tom
> -Ryan Norris
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Column layout for Grid similar to TableColumnLayout? [message #45555 is a reply to message #45525] Mon, 07 January 2008 20:08 Go to previous message
Thanks. I opened the following bug:
Bug 214532 - Open up the API for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214532
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fltu8m$q44$1@build.eclipse.org...
> Tom
>> weight-based column data objects. After I switched to GridTableViewer, I
>> can no longer use either of these because they are specific to the Table
>> widget.
>> org.eclipse.jface.layout.AbstractColumnLayout, and its abstract methods
>> are all package scope and therefore inaccessible. If this class and its
>> abstract methods were public, a Grid-specific version could be
>> Thanks,
>> -Ryan Norris
Re: Column layout for Grid similar to TableColumnLayout? [message #587237 is a reply to message #45495] Mon, 07 January 2008 19:24 Go to previous message
Tom
> -Ryan Norris
Re: Column layout for Grid similar to TableColumnLayout? [message #587251 is a reply to message #45525] Mon, 07 January 2008 20:08 Go to previous message
> Tom
>> widget.
>> Thanks,
>> -Ryan Norris
Previous Topic:Column layout for Grid similar to TableColumnLayout?
Next Topic:How to cancel keyboard event in the Grid?
Current Time: Mon Dec 30 16:31:16 GMT 2024
Powered by FUDForum. Page generated in 0.02583 seconds
