Home » Archived » Memory Analyzer (MAT) » help to interpret results
help to interpret results [message #3970] |
Tue, 02 September 2008 13:44 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Clovis Wichoski![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=clovis.wichoski%40gmail.com) Messages: 1 Registered: July 2009 |
Junior Member |
I discovered Memory Analyzer yesterday on JavaOne on-line, at
http://developers.sun.com/learning/javaoneonline/j1sessn.jsp ?sessn=TS-5729&yr=2008&track=tools
and i have a dump from a production system that crashed after an
OutOfMemory Exception, i take the dump using jmap, and have some doubts
about my problem, i dont know if this is the right place to discuss this,
but maybe my doubt or problem can be shared with another beginner users.
Lets start, i run a Leak Suspects reports, and get the follow result:
Problem Suspect 1
The class "java.lang.ref.Finalizer", loaded by "<system class loader>",
occupies 993,232,720 (84.34%) bytes. The memory is accumulated in class
"java.lang.ref.Finalizer", loaded by "<system class loader>".
Keywords
Accumulated Objects
Class name Shallow Heap Retained Heap Percentage
class java.lang.ref.Finalizer @ 0x2a996901d8 24 993,232,720 84.34%
org.exolab.castor.jdo.engine.DatabaseImpl @
0x2ab31fcd40 88 252,699,544 21.46%
org.apache.xml.dtm.ref.DTMManagerDefault @ 0x2aa5bd74b8 48 22,663,312 1.92%
org.apache.xml.dtm.ref.DTMManagerDefault @ 0x2aa562d310 48 2,759,432 0.23%
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM @ 0x2aaad130a0 312 2,290,104 0.19%
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM @ 0x2aa94d57c0 312 2,289,872 0.19%
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM @ 0x2aa78e0678 312 2,289,632 0.19%
org.apache.xml.dtm.ref.DTMManagerDefault @ 0x2aa99c7d58 48 1,114,392 0.09%
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM @ 0x2aa8680418 312 1,095,624 0.09%
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM @ 0x2ab8a1ee98 312 1,039,056 0.09%
java.lang.ref.Finalizer @ 0x2ae40a6000 64 660,392 0.06%
java.lang.ref.Finalizer @ 0x2ae44edf60 64 660,392 0.06%
java.lang.ref.Finalizer @ 0x2ae4608130 64 660,368 0.06%
java.lang.ref.Finalizer @ 0x2aa9076dc0 64 659,104 0.06%
java.lang.ref.Finalizer @ 0x2ae4e1b428 64 656,928 0.06%
java.lang.ref.Finalizer @ 0x2ab08412c0 64 655,840 0.06%
java.lang.ref.Finalizer @ 0x2aaf299f60 64 626,320 0.05%
java.lang.ref.Finalizer @ 0x2ab733bf28 64 625,584 0.05%
java.lang.ref.Finalizer @ 0x2ae22604e8 64 622,864 0.05%
java.lang.ref.Finalizer @ 0x2aae8bfb78 64 559,608 0.05%
java.lang.ref.Finalizer @ 0x2abac58378 64 557,800 0.05%
Total: 20 entries 2,496 295,186,168 0.251
Accumulated Objects by Class
Label Number Of Objects Used Heap Size Retained Heap Size
org.exolab.castor.jdo.engine.DatabaseImpl 4,757 418,616 253,118,072
com.sap.dbtech.jdbc.ColumnInfo 1,280,189 61,449,072 164,247,360
java.lang.ref.Finalizer 1,025,758 65,648,512 97,918,408
com.sap.dbtech.jdbc.translators.DBTechTranslator[] 176,122 14,468,440 96,665,160
com.sap.dbtech.jdbc.CallableStatementSapDB 179,613 41,670,216 94,770,072
com.sap.dbtech.jdbc.Parseinfo 179,629 21,555,480 65,033,496
com.sap.dbtech.jdbc.ConnectionSapDB 254 54,864 64,875,384
com.sap.dbtech.jdbc.ResultSetSapDB 199,457 23,934,840 44,686,776
org.apache.xml.dtm.ref.DTMManagerDefault 39 1,872 26,855,952
com.sap.dbtech.jdbc.trace.PreparedStatement 174,694 13,975,520 22,351,760
java.lang.String 149,174 5,966,960 15,928,704
org.apache.xml.dtm.ref.sax2dtm.SAX2DTM 70 21,840 15,819,712
org.apache.xpath.XPathContext 39 7,800 7,644,416
com.sap.dbtech.jdbc.StatementSapDB 21,596 2,591,520 6,671,632
org.apache.xalan.templates.ElemTemplate 662 100,624 3,071,408
org.apache.xalan.transformer.TransformerImpl 39 10,920 2,974,880
com.sap.dbtech.jdbc.trace.Statement 21,369 1,367,616 2,395,904
org.apache.xalan.templates.ElemLiteralResult 306 48,960 1,672,768
org.apache.xalan.templates.ElemIf 137 12,056 774,496
org.apache.xalan.templates.StylesheetRoot 39 15,912 763,896
Total: 20 entries 3,413,943 253,321,640 988,240,256
I'm using SUN JVM version on a linux 64bit linux machine:
java version "1.6.0_07"
Java(TM) SE Runtime Environment (build 1.6.0_07-b06)
Java HotSpot(TM) 64-Bit Server VM (build 10.0-b23, mixed mode)
any idea how i can inspect this problem, what path i must follow?
thanks for any help.
Clóvis
Current Time: Wed Jul 24 13:40:52 GMT 2024
Powered by FUDForum. Page generated in 0.03584 seconds
