How to get working PDT? [message #44842] |
Tue, 21 August 2007 20:37 |
Originally posted by: trash.fast-it.net
I extracted pdt-all-in-one-incubation-S20070815_M2-linux-gtk.tar.gz on my
debian 4 system an added also
org.eclipse.php.xdebug.sampleMapper_0.0.2.jar and
XDebugBinContrib_0.2.3.zip (xtracted .jars) to the plugin folder of
eclipse.
After the start I am miss the php-perspective.
eclipse -vmargs -Xmx384M -Xms328M
What's wrong? Do I have to use a certain java-versoin?
Re: How to get working PDT? [message #44875 is a reply to message #44842] |
Tue, 21 August 2007 21:57 |
Originally posted by: dkel50.hotnospmail.com
There are a couple of things. Firstly you need to be running Java 5 (aka
1.5) or later. I haven't tried but I don't think the xdebug support on
bugzilla will work with M2 or later.
Dave Kelsey
Joe wrote:
> Hello,
> my debian 4 system an added also
> eclipse.
Re: How to get working PDT? [message #44895 is a reply to message #44875] |
Tue, 21 August 2007 22:30 |
Hello Dave.
thx! It works fine now.
# java --version
java version "1.4.2"
gij (GNU libgcj) version 4.1.2 20061115 (prerelease) (Debian 4.1.1-20)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
ready-4-it-s01:/raid/daten/apps/programming/php_sdk/eclipse/ pdt#
update-alternatives --config java
Es gibt 5 Alternativen, die »java« bereitstellen.
Auswahl Alternative
1 /usr/bin/gij-wrapper-4.1
*+ 2 /usr/lib/jvm/java-gcj/jre/bin/java
3 /usr/lib/jvm/java-6-sun/jre/bin/java
4 /usr/bin/jamvm
5 /usr/lib/jvm/java-1.5.0-sun/jre/bin/java
Drücken Sie die Eingabetaste, um die Vorgabe[*] beizubehalten,
oder geben Sie die Auswahlnummer ein: 3
Verwende »/usr/lib/jvm/java-6-sun/jre/bin/java«, um »java« bereitzustellen.
# java -version
java version "1.6.0_02"
Java(TM) SE Runtime Environment (build 1.6.0_02-b05)
Java HotSpot(TM) Client VM (build 1.6.0_02-b05, mixed mode, sharing)
FUDForum. Page generated in 0.03028 seconds
