Home » Language IDEs » Java Development Tools (JDT) » Multiple Consoles
Multiple Consoles [message #3879] Thu, 24 April 2003 11:19 Go to next message
Originally posted by: lxie.emageon.com
Hi, All,
How can I run more than 1 Java applications without losing any previous
consoles?
Currently, if I have one running and start another, I loose the first
console.
In JBuilder, I can run many with all consoles visible.
Thanx.
Liang
Re: Multiple Consoles [message #4088 is a reply to message #3879] Thu, 24 April 2003 11:26 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
You can use the icon in the console's toolbar to switch processes.
-t
"Liang Xie" <lxie@emageon.com> wrote in message
news:b88v9d$73f$1@rogue.oti.com...
> Hi, All,
> consoles?
> console.
> Thanx.
> Liang
Re: Multiple Consoles [message #4143 is a reply to message #3879] Thu, 24 April 2003 11:30 Go to previous messageGo to next message
This is possible in Eclipse 2.1. Start 2+ programs that output to the
console. From the console menubar select the program who's output you wish
to view by choosing the drop-down icon that looks like a server+running_guy.
From this drop-down menu you will see a list of running processes to choose
from.
Good luck.
Wayne
> Hi, All,
> consoles?
> console.
> Thanx.
> Liang
Console window request.. [message #6419 is a reply to message #3879] Sat, 26 April 2003 02:09 Go to previous messageGo to next message
Maybe I have missed it, but when I run an ant script, the console window
displays the output. If any errors show up, I have to look at the error, the
class, the line number, etc. Is it possible to make it clickable on a per
line basis, so that I can jump right into the source at the position of the
error for each error?
Thanks.
Re: Console window request.. [message #6456 is a reply to message #6419] Sat, 26 April 2003 10:13 Go to previous message
This is implemented in 2.1 for the Javac task from Ant for various
compilers.
Error output from Javac is handled exactly as you requested. Moving the
mouse over the classname should enable an hyperlink.
See the JavacLineTracker provided in the external tools plugin and the
requested using the org.eclipse.debug.ui.consoleLineTrackers extension
point.
For other tasks you will need to request / contribute to see the work done.
What error output are you describing?
Darins
"Kevin" <supreme_java_guru_1@yahoo.com> wrote in message
news:b8d7v9$8oa$1@rogue.oti.com...
the
the
> Thanks.
Previous Topic:Exception breakpoints
Next Topic:[NEWBIE] How to determine the line-number of a code-fragment?
Current Time: Sun Oct 19 05:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.05067 seconds
