Home » Eclipse Projects » Mylyn » TestTrack Pro connector
TestTrack Pro connector [message #44332] Thu, 28 February 2008 21:10 Go to next message
Alexey Semenov is currently offline Alexey SemenovFriend
Member
Hi!
Does there exist a Mylyn - TestTrack Pro connector? Or maybe some existing
templates for the Generic Web Connector?
I didn't managed to find anything on the web.
Thanks in advance,
Alexey
Re: TestTrack Pro connector [message #44366 is a reply to message #44332] Thu, 28 February 2008 21:58 Go to previous messageGo to next message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
> existing templates for the Generic Web Connector?
Alexey, existing connectors are listed on this page
http://wiki.eclipse.org/Mylyn_Extensions
If you would like to see template for TestTrack Pro for the web
connector, please submit an enhancement request to Mylyn Bugzilla. See
http://www.eclipse.org/mylyn/bugs/
regards,
Eugene
Re: TestTrack Pro connector [message #44394 is a reply to message #44366] Thu, 28 February 2008 22:30 Go to previous messageGo to next message
Member
Hi Eugene,
Thanks for the urls. In Mylyn Bugzilla there already exists a =
corresponding bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D15907=
5
I've voted for it.
Alexey
On Fri, 29 Feb 2008 00:58:35 +0300, Eugene Kuleshov <eu@md.pp.ru> wrote:=
>> Does there exist a Mylyn - TestTrack Pro connector? Or maybe some =
> Alexey, existing connectors are listed on this page =
> If you would like to see template for TestTrack Pro for the web =
> connector, please submit an enhancement request to Mylyn Bugzilla. See=
> regards,
> Eugene
Re: TestTrack Pro connector [message #44425 is a reply to message #44394] Thu, 28 February 2008 22:55 Go to previous messageGo to next message
> corresponding bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=159075
Alex, that issue is for tracking the dedicated connector. If you'd
like to see template for web connector, it would be better to track it
in a separate issue. The easiest would be get access to some test
instance of that tracker or at least get a copy of the html from page
showing list of tasks.
regards,
Eugene
Re: TestTrack Pro connector [message #44455 is a reply to message #44425] Thu, 28 February 2008 23:32 Go to previous message
Member
Eugene,
I've submitted this one: =
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D220850
The description's a bit broken, but I don't see how to edit it.
Thanks for quick responding!
Alexey
On Fri, 29 Feb 2008 01:55:02 +0300, Eugene Kuleshov <eu@md.pp.ru> wrote:=
>> corresponding bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D15=
9075
> Alex, that issue is for tracking the dedicated connector. If you'd =
> like to see template for web connector, it would be better to track it=
> in a separate issue. The easiest would be get access to some test =
> instance of that tracker or at least get a copy of the html from page =
> regards,
> Eugene
Re: TestTrack Pro connector [message #588149 is a reply to message #44332] Thu, 28 February 2008 21:58 Go to previous message
regards,
Eugene
Re: TestTrack Pro connector [message #588158 is a reply to message #44366] Thu, 28 February 2008 22:30 Go to previous message
Member
Hi Eugene,
5
I've voted for it.
Alexey
> regards,
> Eugene
Re: TestTrack Pro connector [message #588166 is a reply to message #44394] Thu, 28 February 2008 22:55 Go to previous message
regards,
Eugene
Re: TestTrack Pro connector [message #588173 is a reply to message #44425] Thu, 28 February 2008 23:32 Go to previous message
Member
Eugene,
Alexey
9075
> regards,
> Eugene
Previous Topic:JIRA Connector: Error when connection via HTTPS
Next Topic:Bugzilla 3.0.3
Current Time: Sat Dec 21 15:05:50 GMT 2024
Powered by FUDForum. Page generated in 0.03074 seconds
