Home » Archived » GEF3D » Specifying Camera Location Programmatically...
Re: Specifying Camera Location Programmatically... [message #3865 is a reply to message #3857] |
Mon, 01 June 2009 19:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Miles,
On 2009-06-01 21:01:06 +0200, Miles Parker <milesparker@gmail.com> said:
> Can it be done? I can't see anywhere in CameraTool API to do this..
Yes, of course. In the default version, "ESC" is a key for reseting the
camera, and other keys can be similarly programmed in subclasses of
CameraTool. Instead of reset, you have to call
org.eclipse.draw3d.camera.ICamera.lookAt(IVector3f, IVector3f).
Jens
Re: Specifying Camera Location Programmatically... [message #3871 is a reply to message #3865] |
Mon, 01 June 2009 21:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Miles Parker![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=milesparker%40gmail.com) Messages: 1341 Registered: July 2009 |
Sorry, I was being dense. I meant by calling a method on CameraTool,
but I see that the camera is actually attached to scene. Again my lack
of knowledge on 3D stuff is showing. It works fine assuming I can get
3D coordinate systems figured out!
On 2009-06-01 12:50:50 -0700, Jens v.P. <developer@jevopi.de> said:
> Hi Miles,
> Cheers,
> Jens
Re: Specifying Camera Location Programmatically... [message #561771 is a reply to message #3857] |
Mon, 01 June 2009 19:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Miles,
Jens
Re: Specifying Camera Location Programmatically... [message #561792 is a reply to message #3865] |
> Hi Miles,
> Cheers,
> Jens
Current Time: Wed Jul 24 13:37:44 GMT 2024
Powered by FUDForum. Page generated in 0.04539 seconds
