Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Accessing a Container via OCL
Accessing a Container via OCL [message #44216] Thu, 10 August 2006 06:21 Go to next message
I have the Model shown below:
Diagram
Nodes1 : references Nodes
Nodes2 : reference OtherNodes
Nodes
String Name
String Summary
etc.
and Nodes1 and Nodes2 are contained in the Diagram.
In the gmfgraph file, I can write OCL validation rules associated with
the Nodes object to ensure that the Name and Summary attributes are not
empty. Also within the GMF I can write an OCL validation rule associated
with the Digram that ensures that the Node Names are unique across the
diagram, e.g.:
self.Nodes1->forAll(n1,n2 |n1<>n2 implies n1.name<>n2.name)
However, when the error is reported this just identifies that there is a
duplicate within the DIAGRAM, not which nodes caused the error. Ideally
I would like to associated the error with the child node, the easiest
way to do this would be access the Container from the child node, is
there a way of accessing the container from a child node, e.g.:
self.CONTAINER.Nodes1 ->
forall( N | self<>N implies N.name=self.name))
If this was the case the error would then be correctly associated with
the child node.
I hope I am asking this question in the correct forum and any help would
be gratefully received.
Many thanks
Alan
Re: Accessing a Container via OCL [message #44338 is a reply to message #44216] Thu, 10 August 2006 09:09 Go to previous messageGo to next message
Hi, Alan,
Currently, OCL does not provide access to the reflective EObject API such as
eContainer(), eClass(), etc. unless your EClasses explicitly extend EObject
in your model. OCL only "sees" the types and features declared in your
ecore model. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=152003 for
details of an open enhancement request for this.
So, your two best possibilities at this point are:
a) add an explicit superclass reference to EObject in your Ecore model.
This is not so easy if you're dealing with the GMF Runtime's notation
model.
b) Provide a custom Environment implementation (extending
EcoreEnvironment) to provide eContainer() etc. as additional operations
and/or properties in your OCL environment. A corresponding custom
EvaluationEnvironment (extending EvalEnvironment) will then be
responsible for evaluating operation/property calls such as
eContainer() by invoking the corresponding EObject API.
HTH,
Christian
> Diagram
> Nodes
> String Name
> String Summary
> etc.
> diagram, e.g.:
> the child node.
> Many thanks
> Alan
Re: Accessing a Container via OCL [message #44503 is a reply to message #44338] Thu, 10 August 2006 10:33 Go to previous messageGo to next message
Hi Christian,
Thanks for your reply.
The Diagram objectcis the Top level object in me ECORE model, which
contains the set of reference to the Nodes. Is this still not accessable?
Alan
Christian W. Damus wrote:
> Hi, Alan,
> model.
> HTH,
> Christian
>>Diagram
>>Nodes
>>String Name
>>String Summary
>>etc.
>>diagram, e.g.:
>>the child node.
>>Many thanks
>>Alan
Re: Accessing a Container via OCL [message #44625 is a reply to message #44503] Thu, 10 August 2006 10:58 Go to previous messageGo to next message
Hi, Alan,
I'm not sure what you mean by top level object in the ecore model. Do you
mean that in a diagram model instance, a Diagram instance will be the root
container (that contains everything else)?
OCL doesn't know anything about Resources, so you can't find an object by
its position in the Resource contents list. However, if you know that a
Resource will contain at most one Diagram instance, then you could use:
Diagram.allInstances()->asSequence()->first()
to get the one and only diagram, as allInstances() is scoped by default to
the Resource. Of course, this assumption may not be valid, in which case
your best bet still may be to add a Node::diagram reference to the diagram,
which might be transient and volatile, derived from eContainer().
Christian
alan newton wrote:
> Hi Christian,
> Alan
>> Hi, Alan,
>> as eContainer(), eClass(), etc. unless your EClasses explicitly extend
>> EObject
>> for details of an open enhancement request for this.
>> notation model.
>> operations
>> HTH,
>> Christian
<snip>
Re: Accessing a Container via OCL [message #44689 is a reply to message #44625] Thu, 10 August 2006 11:35 Go to previous messageGo to next message
Hi Christian,
Below is a pruned version of my Ecore model, the GSN Class is my top
level diagram which contains the collection of references to the Goal
Class. What I am trying to do is from a particular Goal is to go upto
the GSN Class and look in the collection of goals to make sure that only
one Goal with a particular name exists, and if a name exists elsewhere
in the set this particular node is marked as error.
I can write in OCL check at the GSN level to look for duplicate Goal
names, but this just identifies that an error exists not what the error is.
Hopes that clarifies what the model looks like and what I am attempting
to do.
thanks
Alan
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="eArgument"
nsURI="eArgument" nsPrefix="eArgument">
<eClassifiers xsi:type="ecore:EClass" name="Goal">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="GSN">
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="goals"
upperBound="-1"
eType="#//Goal" containment="true"/>
</eClassifiers>
</ecore:EPackage>
> Hi, Alan,
> Cheers,
> Christian
> alan newton wrote:
>>Hi Christian,
>>Alan
>>>Hi, Alan,
>>>EObject
>>> notation model.
>>> operations
>>>HTH,
>>>Christian
> <snip>
Re: Accessing a Container via OCL [message #44720 is a reply to message #44689] Thu, 10 August 2006 13:45 Go to previous messageGo to next message
Hi, Alan,
If you make the changes that I indicated below in your ecore model (added a
Goal::gsn reference and updated the GSN::goals reference; see the text
between *...*), then you will be able to do:
self.gsn.goals->forAll(g | g <> self implies g.name <> self.name)
in the context of Goal. Otherwise, you can try:
self.eContainer().oclAsType(GSN).goals->forAll( ... )
if you take my original suggestion of implementing a custom Environment to
make the eContainer() operation available. For that matter, a "gns"
reference could be added by the Environment in the same way. I'm afraid
there isn't an example that demonstrates how to do this. It should be
quite straight-forward, though.
Christian
alan newton wrote:
> Hi Christian,
> is.
> to do.
> thanks
> Alan
> xmlns:xmi="http://www.omg.org/XMI"
> *<eStructuralFeatures xsi:type="ecore:EReference" name="gsn"
> lowerBound="0"
> eType="#//GSN" eOpposite="#//GSN/goals"/>*
> </eClassifiers>
> upperBound="-1"
> eType="#//Goal" containment="true" *eOpposite="#//Goal/gsn"*/>
> </eClassifiers>
> </ecore:EPackage>
>> Hi, Alan,
>> you mean that in a diagram model instance, a Diagram instance will be the
>> root container (that contains everything else)?
>> to
>> diagram, which might be transient and volatile, derived from
>> eContainer().
>> Cheers,
>> Christian
>> alan newton wrote:
<snip>
Re: Accessing a Container via OCL [message #44862 is a reply to message #44720] Mon, 14 August 2006 09:28 Go to previous message
Hi Christian
Thanks for that, I took the first approach (i.e. a slight modification
to the model) and it works.
Alan
> Hi, Alan,
> Cheers,
> Christian
> alan newton wrote:
>>Hi Christian,
>>is.
>>to do.
>>thanks
>>Alan
>><?xml version="1.0" encoding="UTF-8"?>
>>lowerBound="0"
>> </eClassifiers>
>>upperBound="-1"
>> </eClassifiers>
>></ecore:EPackage>
>>>Hi, Alan,
>>>to
>>>eContainer().
>>>Cheers,
>>>Christian
>>>alan newton wrote:
> <snip>
Re: Accessing a Container via OCL [message #585009 is a reply to message #44216] Thu, 10 August 2006 09:09 Go to previous message
Hi, Alan,
model.
HTH,
Christian
> Diagram
> Nodes
> String Name
> String Summary
> etc.
> diagram, e.g.:
> the child node.
> Many thanks
> Alan
Re: Accessing a Container via OCL [message #585099 is a reply to message #44338] Thu, 10 August 2006 10:33 Go to previous message
Hi Christian,
Alan
> Hi, Alan,
> model.
> HTH,
> Christian
>>Diagram
>>Nodes
>>String Name
>>String Summary
>>etc.
>>diagram, e.g.:
>>the child node.
>>Many thanks
>>Alan
Re: Accessing a Container via OCL [message #585177 is a reply to message #44503] Thu, 10 August 2006 10:58 Go to previous message
Hi, Alan,
Christian
alan newton wrote:
> Hi Christian,
> Alan
>> Hi, Alan,
>> EObject
>> notation model.
>> operations
>> HTH,
>> Christian
<snip>
Re: Accessing a Container via OCL [message #585207 is a reply to message #44625] Thu, 10 August 2006 11:35 Go to previous message
Hi Christian,
to do.
thanks
Alan
</eClassifiers>
upperBound="-1"
</eClassifiers>
</ecore:EPackage>
> Hi, Alan,
> Cheers,
> Christian
> alan newton wrote:
>>Hi Christian,
>>Alan
>>>Hi, Alan,
>>>EObject
>>> notation model.
>>> operations
>>>HTH,
>>>Christian
> <snip>
Re: Accessing a Container via OCL [message #585224 is a reply to message #44689] Thu, 10 August 2006 13:45 Go to previous message
Hi, Alan,
Christian
alan newton wrote:
> Hi Christian,
> is.
> to do.
> thanks
> Alan
> lowerBound="0"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> </ecore:EPackage>
>> Hi, Alan,
>> to
>> eContainer().
>> Cheers,
>> Christian
>> alan newton wrote:
<snip>
Re: Accessing a Container via OCL [message #585287 is a reply to message #44720] Mon, 14 August 2006 09:28 Go to previous message
Hi Christian
Alan
> Hi, Alan,
> Cheers,
> Christian
> alan newton wrote:
>>Hi Christian,
>>is.
>>to do.
>>thanks
>>Alan
>>lowerBound="0"
>> </eClassifiers>
>>upperBound="-1"
>> </eClassifiers>
>></ecore:EPackage>
>>>Hi, Alan,
>>>to
>>>eContainer().
>>>Cheers,
>>>Christian
>>>alan newton wrote:
> <snip>
Previous Topic:EContentAdapter behaviour ?
Next Topic:Requires plug-in "org.eclipse.net4j"
Current Time: Mon Oct 27 20:06:40 EDT 2025
Powered by FUDForum. Page generated in 0.04931 seconds
