Home » Modeling » TMF (Xtext) » importing subpackages of external ecore models
importing subpackages of external ecore models [message #44086] Mon, 18 May 2009 10:28 Go to next message
hi all,
i am developing a dsl for (parts of) an existing ecore model with TMF
(0.7.0M7). this ecore model is very very large and has a complex package
structure.
i can import the whole model from the workspace with:
import " platform:/resource/org.my.projectname/model/externalmodel.ec ore "
as ExternalModel
however, when i try to reference a model element from inside the imported
model, i do not know how to "navigate" to the desired element inside the
package structure. for example:
Class :
'attribute'=[ExternalModel::Some::Packages::ExternalClass] ;
lets the editor return a "Cannot resolve reference to ExternalClass" error
message.
so question 1 is: if i import an external model as described above, how
can i make a reference to a class in a subpackage of that external model?
and question 2 is: if i do not want to import the entire external model,
how can i import only one specific subpackage inside it?
thanks in advance for you help!
Re: importing subpackages of external ecore models [message #44121 is a reply to message #44086] Mon, 18 May 2009 11:55 Go to previous messageGo to next message
Hi Oliver,
please find my comments inline.
Am 18.05.2009 16:28 Uhr, schrieb Oliver:
> hi all,
> structure.
> as ExternalModel
That is correct. This will import the root element from your ecore-resource.
> imported model, i do not know how to "navigate" to the desired element
> inside the package structure. for example:
> Class :
I'm afraid that navigating into subpackages is out of Xtext's scope.
The metamodel alias "ExternalModel" can be used to refer to exactly one
EPackage and provide access to all contained EClassifiers.
> error message.
If you want to refer to elements from subpackages, you'll have to import
them in the same way as the toplevel package. This can either be done by
an URI that includes a fragment to point directly to the subpackage, or
by the ns-URI of the subpackage. I think the latter will only work in
the editor, if the subpackage has been registered in the EPackage
registry through a plugin.xml.
Hope that helps,
Sebastian
Re: importing subpackages of external ecore models [message #44152 is a reply to message #44121] Mon, 18 May 2009 12:24 Go to previous messageGo to next message
hi sebastian,
thanks for your answer. yes, i can now import only the needed subpackage
with:
import
" platform:/resource/org.my.projectname/model/externalmodel.ec ore#//subpackage/subsubpackage "
as ExternalModel
i guess this is the first of your proposed solutions.
another thing:
because of the huge model, the editor gets very slow. after each and every
key stroke the validator seems to validate the grammar. can this feature
be disabled? in my case it would be sufficient to validate "on save"
instead of while typing. this would be a nice feature of TMF.
Re: importing subpackages of external ecore models [message #44183 is a reply to message #44152] Mon, 18 May 2009 13:11 Go to previous messageGo to next message
Hi Oliver,
do you mean the grammar editor gets very slow? Or are you talking about
your specific DSL-Editor?
I assume you mean the latter :-)
If you really mean the editor for the Xtext grammar itself, I would be
glad to have a look into this performance issue. It would be very
helpful, if you can send me your metamodel and your xtext-file to
Sebastian(dot)Zarnekow(at)itemis(dot)de.
However, it is currently not possible to disable the on-keystroke
validator. This may be a serious problem with existing metamodels and
existing EValidators. Would you please be so kind and file a bug?
Sebastian
Am 18.05.2009 18:24 Uhr, schrieb Oliver:
> hi sebastian,
> with:
> import
> as ExternalModel
> another thing:
> every key stroke the validator seems to validate the grammar. can this
> feature be disabled? in my case it would be sufficient to validate "on
> save" instead of while typing. this would be a nice feature of TMF.
Re: importing subpackages of external ecore models [message #44276 is a reply to message #44152] Mon, 18 May 2009 16:40 Go to previous messageGo to next message
Hi Oliver,
if you really ment your DSL editor is slow, this is because the syntax
colorer shipped in M7 was based on parsing the model.
We've changed and improved that, so that validation is not triggered
while you type but in the reconciler (500 ms after you stopped typing).
With the next release (due tomorrow) this will be solved.
Not that this also effects the grammar editor since it used the same
slow implementation.
Sven
Oliver schrieb:
> another thing:
Re: importing subpackages of external ecore models [message #44502 is a reply to message #44276] Tue, 19 May 2009 04:44 Go to previous messageGo to next message
Hi Sebastian and Sven,
i am really talking about the grammar editor, not my DSL editor.
when i import the existing meta-model as described in this thread
(complete or just one subpackage) it gets slow on every key-stroke.
unfortunatelly i cannot provide you the meta-model as is, due to the fact
that it is part of an industrial project. just to mention some key data:
the ecore meta-model has about 850 classes, 800 attributes, 1650
references and a file size of about 6.7 Mb.
Bye,
Oliver.
Re: importing subpackages of external ecore models [message #44532 is a reply to message #44502] Tue, 19 May 2009 05:02 Go to previous messageGo to next message
Hi Oliver,
6.7 Mb is quite impressive for a metamodel.
We are about to release a new Xtext build this afternoon. Please try to
use the grammar editor with this release candidate 1. As Sven already
mentioned, we made several changes that affect the editor's performance
significantly.
Sebastian
Am 19.05.2009 10:44 Uhr, schrieb Oliver:
> fact that it is part of an industrial project. just to mention some key
> data: the ecore meta-model has about 850 classes, 800 attributes, 1650
> Bye,
> Oliver.
Re: importing subpackages of external ecore models [message #44592 is a reply to message #44502] Wed, 20 May 2009 00:52 Go to previous messageGo to next message
> Bye,
> Oliver.
Hi Oliver,
You should probably split your huge domain model (of 850 classes) to
smaller sub-domain models and provide different DSL for each sub-domain
model you intend to provide a textual editor. I am using a similar domain
model (HL7 MIF2 with aprox. 850 classes, maybe is the same hehe), but I
never considered importing all classes at once into Xtext. I focus at one
aspect at the time and I use intermediate models to import in Xtext or to
apply other M2M/M2T transformations or graphical editors (using GMF).
Ioan
Re: importing subpackages of external ecore models [message #45187 is a reply to message #44532] Mon, 25 May 2009 03:55 Go to previous message
Hi all,
I now installed the newest Xtext release and must say: good work! The
performance of the grammar editor improved significantly.
However, I also must consider Ioan's proposal of not to import (packages
of) the whole model, but to create a splitted small model of the parts of
interest.
Thank you all for your help.
Oliver.
> significantly.
> Sebastian
Previous Topic:[Xtext] Can any compare Xtext with TCS?
Next Topic:XML Meta Model
Current Time: Sat Oct 18 12:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
