Testing RCP Applications [message #44083] |
Mon, 20 July 2009 10:45 |
Denis Ungemach Messages: 3 Registered: July 2009 |
Junior Member |
I try to test a RCP-Application (com.dmissoh.rcp.mail, it`s the mail
samplecode from the Plugin-Wizard). The test works in eclipse, but it
doesn`t work in console with an ant script and the exported product.
Both videotutorials worked fine, but after i`ve changed the details of the
ant script to the mail product it didn`t work anymore.
build.xml:
<?xml version="1.0" encoding="UTF-8" ?>
<project name="testsuite" default="run" basedir="." >
<property name="eclipse-home" value="C:\SWTBotTest\Mail" />
<property name="plugin-name" value="swtbot.example" />
<property name="test-classname" value="MyFirstTest" />
<property name="library-file"
value=" ${eclipse-home}\plugins\org.eclipse.swtbot.eclipse.junit4.he adless_2.0.0.371-dev-e35\library.xml "
<target name="suite" >
<property name="jvmOption" value="" ></property>
<property name="temp-workspace" value="workspace" />
<delete dir="${temp-workspace}" quiet="true" />
<ant target="swtbot-test" antfile="${library-file}" dir="${eclipse-home}"
<property name="data-dir" value="${temp-workspace}" />
<property name="testProduct" value="com.dmissoh.rcp.mail.product" />
<property name="plugin-name" value="${plugin-name}" />
<property name="os" value="win32" />
<property name="ws" value="win32" />
<property name="arch" value="x86" />
<property name="classname" value="swtbot.example.MyFirstTest" />
<property name="vmargs" value="-Xms128M -XX:MaxPermSize=512m -Xmx512M" />
</ant>
</target>
<target name="cleanup" />
<target name="run" depends="suite,cleanup">
</target>
</project>
report:
Install location:
file:/c:/SWTBotTest/Mail/
Configuration file:
file:/c:/SWTBotTest/Mail/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/SWTBotTest/Mail/plugins/org.eclipse.osgi_3.4.3.R34x _v20081215-1030.jar
Framework classpath:
Debug options:
file:/C:/SWTBotTest/Mail/.options not found
Time to load bundles: 15
Starting application: 1094
!SESSION 2009-07-20 12:31:32.093
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application
org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion -product
formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,C:\SWTBotTest\Mail/swtbot.example.MyFirst Test.xml
formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter
-testPluginName swtbot.example -className swtbot.example.MyFirstTest
Command-line arguments: -application
com.dmissoh.rcp.mail.product -data workspace
-testPluginName swtbot.example -className swtbot.example.MyFirstTest -os
win32 -ws win32 -arch x86 -consoleLog -debug
!ENTRY org.eclipse.osgi 4 0 2009-07-20 12:31:33.250
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
" org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion " could
not be found in the registry. The applications available are:
com.dmissoh.rcp.mail.application, org.eclipse.equinox.app.error.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.core.launcher.Main.main(Main.java:30)
Re: Testing RCP Applications [message #44426 is a reply to message #44119] |
Tue, 21 July 2009 07:02 |
Junior Member |
> To execute the headless tests, you'll need to additionally download the
> 'headless testing framework' from the download site. Before you execute
> the tests, knock off the junit3 (or junit4) plugins from the headless
> plugin.
I downloaded them and i did everything in the same way i did in the
tutorial, but i found my mistake. This time i added the plugins
(org.eclipse.swtbot.eclipse.core;bundle-version="2.0.0",
org.eclipse.swtbot.eclipse.finder;bundle-version="2.0.0",
org.eclipse.swtbot.eclipse.ui;bundle-version="2.0.0",
org.eclipse.swtbot.junit4_x;bundle-version="2.0.0",
org.eclipse.swtbot.swt.finder;bundle-version="2.0.0",
swtbot.example;bundle-version="1.0.0" (my testplugin),
org.hamcrest;bundle-version="1.1.0",
org.junit4;bundle-version="4.3.1",
org.eclipse.swtbot.eclipse.junit4.headless;bundle-version="2.0.0 ")
to the dependencies of the plugin and then i exported the product, now its
working. The last time i just copied them in the plugins-directory of my
product.
I think , if i just copy these plugins to the exported product, i have to
change the configuration.
Thanks anyway.
FUDForum. Page generated in 0.03409 seconds
