[NEWBIE] How to determine the line-number of a code-fragment? [message #3832] |
Thu, 24 April 2003 09:32  |
could anybody please provide me with information on how to find a line
number of a code fragment in a corresponding Java-resource-file?
In my program, I have a IJavaElement in an ICompilationUnit. This
IJavaElement has a Source-Range, but I would like to set a
JavaLineBreakpoint (programatically) at the line of the statement.
The only way I found of determining the line is -- well -- funny
(offset is the offset of the source fragment, window is an
IWorkbenchWindow):
// First, create a new TextSelection
TextSelection select = new TextSelection(offset, 1);
// Now, set this TextSelection in the active editor
window.getActivePage().getActiveEditor().getEditorSite().
getSelectionProvider().setSelection(select);
// And retrieve the selection again.
ISelection sel = window.getActivePage().getActiveEditor().getEditorSite().
getSelectionProvider().getSelection();
// Now, the lineNumber can be retrieved.
int lineNumber = ((TextSelection) sel).getStartLine();
// Clear the selection again...
getSelectionProvider().setSelection(TextSelection.emptySelec tion());
Apart from being ugly, this code only works, if the file that contains my
source fragment is currently open in the active editor...
Now, there has to be a better way of retrieving the line number, right?
Thanks for your help.
Philipp Bouillon
Re: [NEWBIE] How to determine the line-number of a code-fragment? [message #6475 is a reply to message #4213] |
Sat, 26 April 2003 11:32  |
If your file is open in the editor, the best way is to get the editor's
underlying document.
Assuming you have a ICompilationUnit cu in hand:
IFile correspondingFile;
if (cu.isWorkingCopy() {
correspondingFile= (IFile) cu.getOriginalElement().getResource();
} else {
correspondingFile= (IFile) cu.getResource();
IDocument doc=
JavaUI.getDocumentProvider().getDocument(
new FileEditorInput(correspondingFile));
....doc.getLineOfOffset(..)...
Martin
Jesper Kamstrup Linnet wrote:
> Adam Kiezun wrote:
>> i see 2 easy ways:
>> - parse the file and call CompilationUnit.lineNumber(position), or
>> - create an IDocument for the file and call IDocument.getLineOfOffset
>> a.
>> eclipse.org
> Hi Adam,
> Which of these ways is the best performancewise if you only want to
> obtain the line number?
> Best regards,
> Jesper
FUDForum. Page generated in 0.04639 seconds
