Home » Archived » XML Schema Definition (XSD) » ComplexType error help
ComplexType error help [message #43799] Thu, 06 May 2004 10:15 Go to next message
Ed,
I have the following ComplexType :
<xs:complexType abstract="false" mixed="false" name="Array">
<xs:annotation/>
<xs:group maxOccurs="1" minOccurs="0" ref="Q1:Array"/>
<xs:attributeGroup ref="Q1:arrayAttributes"/>
<xs:attributeGroup ref="Q1:commonAttributes"/>
</xs:complexType>
.... which is the base type for this ComplexType in another schema:
<xs:complexType abstract="false" mixed="false" name="TaxInfoArray">
<xs:complexContent>
<xs:restriction base="Z1:Array">
<xs:sequence maxOccurs="1" minOccurs="1">
<xs:element maxOccurs="unbounded" minOccurs="0"
name="TaxInfo" type="Q1:TaxInfo"/>
</xs:sequence>
<xs:attributeGroup ref="Z1:arrayAttributes"/>
<xs:attributeGroup ref="Z1:commonAttributes"/>
</xs:restriction>
</xs:complexContent>
</xs:complexType>
I'm getting the following validation error for the second type : XSD: The
restricted content type must accept a subset of the content accepted by the
base type.
What is causing this error?
thanks,
lp
Re: ComplexType error help [message #43829 is a reply to message #43799] Thu, 06 May 2004 11:40 Go to previous messageGo to next message
> </xs:sequence>
is not a subset of
but without group knowing what "Q1:Array" is, it is hard to say more.
norwood sisson
Lance Phillips wrote:
> Ed,
> <xs:annotation/>
> </xs:complexType>
> <xs:complexContent>
> </xs:sequence>
> </xs:restriction>
> </xs:complexType>
> base type.
> thanks,
> lp
Re: ComplexType error help [message #43859 is a reply to message #43799] Thu, 06 May 2004 12:01 Go to previous message
Lance,
I'd have to see the definition of the "Array" group to provide a detailed
answer. XSD uses a DFA subsetting algorithm to determine this diagnostic; the
base type must accept anything that the restricted type allows...
> Ed,
> <xs:annotation/>
> </xs:complexType>
> <xs:complexContent>
> </xs:sequence>
> </xs:restriction>
> </xs:complexType>
> base type.
> thanks,
> lp
Re: ComplexType error help [message #586793 is a reply to message #43799] Thu, 06 May 2004 11:40 Go to previous message
> </xs:sequence>
is not a subset of
norwood sisson
> Ed,
> <xs:annotation/>
> </xs:complexType>
> <xs:complexContent>
> </xs:sequence>
> </xs:restriction>
> </xs:complexType>
> base type.
> thanks,
> lp
Re: ComplexType error help [message #586809 is a reply to message #43799] Thu, 06 May 2004 12:01 Go to previous message
Lance,
> Ed,
> <xs:annotation/>
> </xs:complexType>
> <xs:complexContent>
> </xs:sequence>
> </xs:restriction>
> </xs:complexType>
> base type.
> thanks,
> lp
Previous Topic:ComplexType error help
Next Topic:XMI 2.0 spec. questions
Current Time: Tue Apr 29 02:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.30781 seconds
