Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #43771 is a reply to message #43758] |
Tue, 02 November 2004 16:43 |
Originally posted by: mchapman.uk.ibm.com
On Tue, 02 Nov 2004 14:24:10 +0000, Prashant wrote:
> Hi. This is the first time i am using ajdt. I downloaded the 1.2.0M1
> release and unzipped it into my eclipse directory.
> But now whenever i try to create a new AspectJ project it gives me an
> error saying -
> "The selected wizard could not be started.
> Plug-in org.eclipse.adjt.ui was unable to load class
> org.eclipse.ajdt.internal.ui.wizards.AspectJProjectWizard"
> I have Eclipse 3.0 installed. A similar kind of error i get when trying to
> access the adjt page in the preferences window.
> Is this some kind of bug?
> PRASHANT
It sure looks like something has gone badly wrong for you. I've never
heard of it doing this for others. I suspect there is something incorrect
or unusual about your environment or setup. Please raise a bug report for
this, with as much detail as possible, and we'll pursue it there.
Matt.
Re: 1.2.0M1 showing error msg (MAJOR bug possibly) [message #43953 is a reply to message #43832] |
Thu, 04 November 2004 14:55 |
On Wed, 03 Nov 2004 11:28:00 +0000, Prashant wrote:
> Hi i got the solution.
> You need to document your stuff better ;)
> The above problem occurs only when you already have an existing workspace
> and you try to create an AJDT project in it. But if you create an
> altogether new workspace in a new directory, the problem goes away. The
> same bug is in 1.1.12 also.
> You need to specify on the download page to create a new workspace after
> installing AJDT otherwise none of its components would work in an existing
> workspace.
Hi, I'm glad things are working for you now.
We haven't documented this issue, because we've not been aware of it
before. We have successfully installed AJDT with existing workspaces, as I
believe others have too. But I don't know why it didn't work for you.
Matt.
FUDForum. Page generated in 0.04074 seconds
