Home » Eclipse Projects » Plugin Development Environment (PDE) » How to exclude test directory in Export
How to exclude test directory in Export [message #43505] Mon, 02 February 2009 06:25 Go to next message
Mikael Petterson is currently offline Mikael PettersonFriend
When I do an Export --> Plugin-in Development --> Deployable Features in
Eclipse 3.4 I get an build error caused by my newly added test package.
There is no problem when I am working on the plug-in. But when I do an
export I get the message that the classes that my plugin extends is not
possible to reslove. What is the best option:
1. Exclude the test directory in an Export.
2. Include it in the class path for the Export.
How can I do either of the options in my plugin.xml ( or feature.xml).
cheers,
//mikael
Re: How to exclude test directory in Export [message #43567 is a reply to message #43505] Mon, 02 February 2009 07:20 Go to previous message
Manuel Selva is currently offline Manuel SelvaFriend
Hi Mikael,
Can you provide us the error message you got when you try to export your
plugin ?
I think you should not include your tests in your exported plugin, and
moreover I think your tests should be in a dedicated plugin (for concerns
separation purpose)
Manu
Re: How to exclude test directory in Export [message #590919 is a reply to message #43505] Mon, 02 February 2009 07:20 Go to previous message
Hi Mikael,
plugin ?
separation purpose)
Manu
Previous Topic:How to exclude test directory in Export
Next Topic:Providing Images
Current Time: Fri Dec 27 03:16:01 GMT 2024
Powered by FUDForum. Page generated in 0.03237 seconds
