Home » Eclipse Projects » Mylyn » Want to use mylyn with gForge
Want to use mylyn with gForge [message #43434] Mon, 18 February 2008 13:59 Go to next message
Originally posted by: benjamin.diegelmann.edag.de
Can anyone tell me how to configure mylyn to use GForge?
If tried before but I canŽt get it running.
Re: Want to use mylyn with gForge [message #43469 is a reply to message #43434] Mon, 18 February 2008 18:01 Go to previous messageGo to next message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
There is web connector for Mylyn that allows to retrieve tasks from
various web issue trackers. You can see instructions for configuring web
connector in the user guide at [1]. There is also preconfigured template
for GForge (ASM project at objectweb.org) that you can select from the
drop down on web connector repository configuration page.
regards,
Eugene
[1]
http://wiki.eclipse.org/Mylyn_User_Guide#Generic_Web_Reposit ory_Connector
Re: Want to use mylyn with gForge [message #43532 is a reply to message #43469] Tue, 19 February 2008 07:37 Go to previous messageGo to next message
Thx for your reply,
I know that generic web connector, but IŽve got a problem with the
configuration of it.
Seems that I do not have the correct settings for the gforge platform.
Maybe you can give me a hint where to find the template on the
objectweb.org site.
Re: Want to use mylyn with gForge [message #43563 is a reply to message #43532] Tue, 19 February 2008 08:12 Go to previous messageGo to next message
Benjamin,
The link gave in my previous email was pointing to the step by step
instructions for configuring web connector. Once you have connector
installed, you can create new task repository for the web connector and
select preconfigured template from the "Server" drop down on repository
properties dialog for the web connector.
regards,
Eugene
Benjamin Diegelmann wrote:
> Thx for your reply,
> objectweb.org site.
Re: Want to use mylyn with gForge [message #43595 is a reply to message #43563] Tue, 19 February 2008 08:35 Go to previous messageGo to next message
Originally posted by: mauro.molinari.cardinis.com
Eugene Kuleshov ha scritto:
> Benjamin,
> regards,
> Eugene
Hi Eugene,
I haven't tried the generic web connector yet, although I may try to use
it to access a jTrac installation (http://jtrac.info). Do you know of
any attempt to make a template for jTrac?
Unfortunately, the makers of jTrac did try twice to create a Mylar/Mylyn
connector, but as they don't have expertise on Eclipse development, they
gave up both times... :-(
http://sourceforge.net/forum/forum.php?thread_id=1675418& ;forum_id=552477
Mauro.
Re: Want to use mylyn with gForge [message #43626 is a reply to message #43595] Tue, 19 February 2008 10:57 Go to previous messageGo to next message
I know what you are meaning. But my problem is that the given
configuration of the template for asm project doesnŽt work for me.
I donŽt know why, cause there is no error listed.
I can not see any tasks, or do something else. There must be some failure
in the advanced configuration urls.
Re: Want to use mylyn with gForge [message #43711 is a reply to message #43626] Tue, 19 February 2008 18:52 Go to previous messageGo to next message
> configuration of the template for asm project doesn't work for me.
> I don't know why, cause there is no error listed.
> failure in the advanced configuration urls.
Have you tried the troubleshooting steps suggested in the web
connector FAQ entry at [1] ?
Next weekly build will also have "Open" button in the query
configuration page so you should be easily see actually downloaded page
without using wget. Then once you'll see that desired page is
downloaded, you can use query pattern preview to see if your current
pattern is working. You can also send me your web page if you need some
help with the pattern.
regards,
Eugene
[1]
http://wiki.eclipse.org/Mylyn_FAQ#Why_can.27t_I_connect_usin g_one_of_the_existing_templates.3F
Re: Want to use mylyn with gForge [message #43782 is a reply to message #43595] Tue, 19 February 2008 19:56 Go to previous message
> use it to access a jTrac installation (http://jtrac.info). Do you know
> of any attempt to make a template for jTrac?
> Mylar/Mylyn connector, but as they don't have expertise on Eclipse
> development, they gave up both times... :-(
Mauro, please submit an enhancement request for jtrac template for
Mylyn web connector and specify if there is a public repository that
could be used for testing.
Eugene
Re: Want to use mylyn with gForge [message #587851 is a reply to message #43434] Mon, 18 February 2008 18:01 Go to previous message
regards,
Eugene
[1]
Re: Want to use mylyn with gForge [message #587868 is a reply to message #43469] Tue, 19 February 2008 07:37 Go to previous message
Thx for your reply,
objectweb.org site.
Re: Want to use mylyn with gForge [message #587873 is a reply to message #43532] Tue, 19 February 2008 08:12 Go to previous message
Benjamin,
regards,
Eugene
> Thx for your reply,
> objectweb.org site.
Re: Want to use mylyn with gForge [message #587885 is a reply to message #43563] Tue, 19 February 2008 08:35 Go to previous message
Mauro Molinari is currently offline Mauro MolinariFriend
> Benjamin,
> regards,
> Eugene
Hi Eugene,
Mauro.
Re: Want to use mylyn with gForge [message #587898 is a reply to message #43595] Tue, 19 February 2008 10:57 Go to previous message
Benjamin is currently offline BenjaminFriend
Re: Want to use mylyn with gForge [message #587929 is a reply to message #43626] Tue, 19 February 2008 18:52 Go to previous message
regards,
Eugene
[1]
Re: Want to use mylyn with gForge [message #587944 is a reply to message #43595] Tue, 19 February 2008 19:56 Go to previous message
Eugene
Previous Topic:[Trac] Cannot retrieve existing context
Next Topic:Generic Web Connector timeout
Current Time: Fri Dec 27 03:03:14 GMT 2024
Powered by FUDForum. Page generated in 0.05038 seconds
