Home » Modeling » OCL » Query evaluate DynamicEObjectImpl problem.
| Query evaluate DynamicEObjectImpl problem. [message #43381] |
Fri, 16 November 2007 04:44  |
Originally posted by: yann.davin.gmail.com
Hi all,
I've some problems with query evaluation.
I have a ocl file with my constraints I parse it and for each invariant,
I do a query on my emf resource to get all eobjects concerned by the
context.But when I try to execute the query statement on the eobjects
returned by the query I have a exception with a
org.eclipse.emf.ecore.impl.DynamicEObjectImpl message.
For the moment to solve the problem I create a tmp resource where I put
a copy of the eojects returned by the query but it is not really clean.
I would like to know if there is a way to apply evaluate directly on the
eobjects return by the ocl query without copying eobjects in a tmp resource.
---sample of code that fails----
for (Constraint constraint : ocl.parse(oclInput)) {
if (isInvariant(constraint)) {
Query<EClassifier, EClass, EObject> eval = ocl
.createQuery(constraint);
Condition contextTypeCondition = new
BooleanOCLCondition<EClassifier, EClass, EObject>(
ocl.getEnvironment(), "self.oclIsTypeOf("
+ constraint.getSpecification()
.getContextVariable().getType()
.getName() + ")",
FractaladlPackage.Literals.SYSTEM);
SELECT contextTypeStatement = new SELECT(SELECT.UNBOUNDED,
false, new FROM(modifiedResource.getContents()),
new WHERE((EObjectCondition) contextTypeCondition),
new NullProgressMonitor());
IQueryResult iresults2 = contextTypeStatement.execute();
//problem evaluate on iresults2.getObjects raises
// exception DynamicEObjectImpl
//problem solved if iresults2.getObjects are copied and put in a
//temp resource.
Collection<?> result = (Collection<?>) eval
.evaluate(iresults2.getEObjects());
System.out.println(eval.queryText() + ":" + result);
Yann
| Re: Query evaluate DynamicEObjectImpl problem. [message #43412 is a reply to message #43381] |
Fri, 16 November 2007 08:42   |
Hi, Yann,
I don't quite follow your scenario. The exception has a message stating
simply "org.eclipse.emf.ecore.impl.DynamicEObjectImpl?" That sounds like a
ClassCastException. It would help greatly if you can post the exception's
stack trace.
I can't think of any reason why copying the objects to a temporary resource
should fix anything. They would still be dynamic EObjects ... In any case,
you shouldn't need to do this. I'll need a stack trace to see what is
happening.
BTW, did you know that you can simply do EcoreUtil.getObjectsByType(...) to
select all of the objects conforming to an EClassifier from a collection?
Collection<?> iresults2 = EcoreUtil.getObjectsByType(
modifiedResource.getContents(),
Christian
yann davin wrote:
> Hi all,
> resource.
> .getName() + ")",
> //temp resource.
> Thanks
> Yann
| Re: Query evaluate DynamicEObjectImpl problem. [message #43472 is a reply to message #43412] |
Fri, 16 November 2007 09:24  |
Yes it is a cast exception, you are right.
eval.evaluate(iresults2.getEObjects()); works
but the (Collection<?>) cast fails. Collection<?> result = (Collection<?>) eval.evaluate(iresults2.getEObjects());
So it's not a ocl issue, sorry...
Anyway thanks very much you for your help, I don't have to do a copy anymore, and I use EcoreUtil.getObjectsByType() as
you told me, it works pretty well :)
Christian W. Damus a écrit :
> Hi, Yann,
> stack trace.
> happening.
> Cheers,
> Christian
> yann davin wrote:
>> Hi all,
>> resource.
>> .getName() + ")",
>> //temp resource.
>> Thanks
>> Yann
Current Time: Fri Oct 24 06:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.08205 seconds
