Home » Archived » BIRT » Report Viewer
Report Viewer [message #43292] Mon, 06 June 2005 11:46
Christian BEZARD is currently offline Christian BEZARDFriend
I have created a report in report designer.
DataSource access a MySQL database. DataSet is OK : I see the result in the
Edit Data Set .
When I See the preview or the PDF report, an error occurs :
id short lastname firstname reportto department pwd security
email active
There are errors on the report page:Error1:Impossible d?tablir la connexion
pour le pilote ({0}).Cannot load JDBC Driver class: [com.mysql.jdbc.Driver].
Cannot load JDBC Driver class: [com.mysql.jdbc.Driver]. Any help is
appreciated.
Previous Topic:SQL Server DataSource Parameters
Next Topic:BIRT 1.0 released
Current Time: Fri Dec 27 00:05:18 GMT 2024
Powered by FUDForum. Page generated in 0.03162 seconds
