Ant, Eclipse Config and JRE [message #43262] |
Thu, 29 May 2003 13:27  |
Originally posted by: dougr.rmsfinance.com
When I attempt to use ExternalTools:Ant to compile, I get the following
error:
"[javac] BUILD FAILED: file:H:/eclipse/workspace/.../build.xml:118: Unable
to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK"
Relevant Info:
[1] running Eclipse version 2.1 on Windows 2000
[2] Java_Home is set to the JDK directory: E:\j2sdk1.4.1_01
[3] when I execute an Ant Echo Task in Eclipse ( <echo message="java.home
= ${java.home}"/> ), it does indicate that java.home points to the JRE
instead: E:\j2sdk1.4.1_01\jre,
[4] I can see that Eclipse gets its information from the Windows Registry
rather than the Windows Environment variables [JAVA_HOME] that Tomcat, Ant
and other java-based programs use. There are JAVAHOME keys for the JDK
and the JRE. I have [a] verified that the JDK and JRE keys point to the
correct locations.
And [b] I have tried to change the JRE key. When I make this change,
Eclipse fails to launch. So I had to change it back.
[5] Environment Variable - Classpath - does contain entry for Tools.jar
which holds the class - com.sun.tools.javac.Main - Ant needs.
How do I configure Eclipse to tell it where Java_Home is so that Ant can
find the class in Tools.jar it needs to compile?
Douglas Reames
RMS Finance
919 929 3465
Re: Ant, Eclipse Config and JRE [message #43955 is a reply to message #43262] |
Thu, 29 May 2003 21:34  |
Originally posted by: yongw2.21cn.com
I have asked the same question just a few days ago, see the forwared
message:
I think it's enough to add tools.jar (from your JDK/lib directory) to ant
classpath in Eclipse (Window/Preferences/Ant/Runtime/Classpath/Add JARs...)
peter
"Yong WANG" <yongw2@21cn.com> wrote in message
news:bauq51$5sq$1@rogue.oti.com...
> I have installed Eclipse 2.1 on Win2k, the ANT plugin is version 1.5.2.
> I also installed ANT 1.5.3 for command line use.
> When I use "javac" task in one build.xml file, all goes smoothly in
command
> line. But if i use it in the Eclipse environment, i always get the error
> message
> file:G:/eclipse/workspace/jtmn/src/jasn/parser/build.xml:23: Unable to
find
> a javac compiler;
> I checked many times the I have correctly set the JAVA_HOME environment,
> what is wrong?
"douglas reames" <dougr@rmsfinance.com> ??????:bb5fut$a4s$1@rogue.oti.com...
> error:
> Relevant Info:
> correct locations.
> Douglas Reames
> RMS Finance
> 919 929 3465
FUDForum. Page generated in 0.06751 seconds
