Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build, P2 metadata: qualifiers for features missing..
PDE Build, P2 metadata: qualifiers for features missing.. [message #43061] Thu, 29 January 2009 14:59 Go to next message
I'm generating p2 metadata as part of my build.
While the plugins get the appropriate qualifiers placed in them, the
features end up like:
my.great.feature_1.x.y.qualifier
This is true even though the final build in my build directory contains
features wiht the appropriate qualifiers!
Anyone have an idea of what may be going wrong here? Or is this simply
not generated for p2?
Here are the relvant build.properties..
repoDir=/Volumes/Resources/Developer/repos
ascapeDir=${repoDir}/ascape
metaabmDir=${repoDir}/metaabm
metascapeDir=${repoDir}/metascape
generate.p2.metadata=true
topLevelElementType = feature
topLevelElementId = org.metaabm.feature
archivePrefix=metascape
collectingFolder=${archivePrefix}
configs = *,*,*
p2.metadata.repo=file:${metascapeDir}/com.metascape.build_p2 site
p2.metadata.repo.name = Metascape Tools
p2.artifact.repo=file:${metascapeDir}/com.metascape.build_p2 site
p2.artifact.repo.name = Metascape Tools
p2.publish.artifacts=true
p2.flavor=tooling
buildDirectory=${metascapeDir}/com.metascape.build_pde/build
base=/Developer/eclipseI13
baseLocation=${base}/eclipse
#Os/Ws/Arch/nl of the eclipse specified by baseLocation
baseos=macos
basews=cocoa
basearch=x86
# Type of build. Used in naming the build output. Typically this value is
# one of I, N, M, S, ...
buildType=M
# ID of the build. Used in naming the build output.
buildId=main
skipBase=true
#skipMaps=true Defined using copy in a map file
javacSource=1.5
javacTarget=1.5
generateFeatureVersionSuffix=true
Where the site is just an ordinary site project.
allElements.xml is default and the only changes to customTargets.xml is:
<target name="getMapFiles" depends="checkLocalMaps" unless="skipMaps">
</target>
<target name="checkLocalMaps">
<available property="mapsLocal" file="${buildDirectory}/maps" />
</target>
Where local maps looks like:
ature@org.metaabm.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.ascape.core=COPY,/Volumes/Resources/Developer/repos/ascape/,
plugin@org.ascape.ui.swing=COPY,/Volumes/Resources/Developer/repos/ascape/,
plugin@org.ascape.common.lib=COPY,/Volumes/Resources/Developer/repos/ascape/,
feature@org.ascape.common.feature=COPY,/Volumes/Resources/Developer/repos/ascape/,
plugin@org.metaabm.core=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.eclipse.emf.java=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.edit=COPY,/Volumes/Resources/Developer/repos/metaabm/,
feature@org.metaabm.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.gen=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.gen.ascape=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.gis.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.ide=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.ide.ascape=COPY,/Volumes/Resources/Developer/repos/metaabm/,
feature@org.metaabm.ide.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@org.metaabm.ide.gis=COPY,/Volumes/Resources/Developer/repos/metaabm/,
feature@org.metaabm.gis.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
feature@org.metaabm.target.ascape.feature=COPY,/Volumes/Resources/Developer/repos/metaabm/,
plugin@com.metascape.ide.docs=COPY,/Volumes/Resources/Developer/repos/metascape/,
feature@com.metascape.ide.docs.feature=COPY,/Volumes/Resources/Developer/repos/metascape/,
Re: PDE Build, P2 metadata: qualifiers for features missing.. [message #44273 is a reply to message #43061] Tue, 03 February 2009 14:09 Go to previous messageGo to next message
Miles,
What version of eclipse are you using?
There was a bug in the version replacement code
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=261863).
This was introduced in pde.build v20090112 and fixed in v20090203
-Andrew
> configs = *,*,*
> p2.flavor=tooling
> baseos=macos
> basews=cocoa
> basearch=x86
> buildType=M
> buildId=main
> skipBase=true
> javacSource=1.5
> javacTarget=1.5
> </target>
> </target>
Re: PDE Build, P2 metadata: qualifiers for features missing.. [message #44975 is a reply to message #44273] Wed, 04 February 2009 14:14 Go to previous message
Why, the broken one of course. What else? Even after many I builds I
still end up thinking that its just something that I've missed
somewhere. I downgraded and the qualifiers worked perfectly. I'm going
to try the 20090203 build for the site stuff as it looks almost as
solid as the M5.
On 2009-02-03 11:09:55 -0800, Andrew Niefer <aniefer@ca.ibm.com> said:
> Miles,
> -Andrew
>> configs = *,*,*
>> p2.flavor=tooling
>> baseos=macos
>> basews=cocoa
>> basearch=x86
>> buildType=M
>> buildId=main
>> skipBase=true
>> javacSource=1.5
>> javacTarget=1.5
>> </target>
>> </target>
Re: PDE Build, P2 metadata: qualifiers for features missing.. [message #591189 is a reply to message #43061] Tue, 03 February 2009 14:09 Go to previous message
Miles,
-Andrew
> configs = *,*,*
> p2.flavor=tooling
> baseos=macos
> basews=cocoa
> basearch=x86
> buildType=M
> buildId=main
> skipBase=true
> javacSource=1.5
> javacTarget=1.5
> </target>
> </target>
Re: PDE Build, P2 metadata: qualifiers for features missing.. [message #591377 is a reply to message #44273] Wed, 04 February 2009 14:14 Go to previous message
solid as the M5.
> Miles,
> -Andrew
>> configs = *,*,*
>> p2.flavor=tooling
>> baseos=macos
>> basews=cocoa
>> basearch=x86
>> buildType=M
>> buildId=main
>> skipBase=true
>> javacSource=1.5
>> javacTarget=1.5
>> </target>
>> </target>
Previous Topic:pde build with maven
Next Topic:Export plugin build problem
Current Time: Tue Oct 14 01:02:23 EDT 2025
Powered by FUDForum. Page generated in 0.04785 seconds
