Re: [buckminster-dev] help with CVS [message #3677] |
Thu, 14 February 2008 16:10 |
Hi Todd,
Buckminster has no special requirements for CVS support other then that
the Buckminster CVS feature is installed. It uses the built in CVS
support provided by the Eclipse IDE. If that works, Buckminster should
also work. I can't see anything wrong with your setup. So first question
I have to ask is - are you able to check out the
org.demo.hello.xml.world project into your workspace using the Eclipse CVS?
- thomas
Todd_Lee@amis.com wrote:
> Hi there,
> So I tried with little success yesterday to use buckminster in our local
> environment. After a bit of investigation, I'm wondering if it has
> something to do with our CVS repository?
> As a bit of background, no matter what I try to resolve, I seem to get
> errors like the following:
> Found searchPath default for component org.demo.hello.xml.world
> ERROR [0001] : No suitable provider for component
> org.demo.hello.xml.world:osgi.bundle was found in searchPath default
> ERROR [0001] : Provider
> cvs(:pserver:leet@sam :/usr/local/share/projects/cvsrep,swt_root/scratch/leet/buck minstertest/helloworld/org.demo.hello.xml.world):
> No match found for component org.demo.hello.xml.world
> After banging my head on my desk for a while, I thought I'd try to
> eliminate possible sources of error so I elected to try a local setup with
> the 'hello world xml' demo which I know works (btw - thanks Thomas, svn
> works now!). I exported the resolved/materialized (from eclipse svn repo)
> sources and added them to my local CVS for a test.
> I made a local copy of the cquery available on our network with the
> following contents (filename: hwdemo.cquery):
> <cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
> resourceMap="http://sam/ide/updates/dev/hwdemo.rmap">
> <cq:rootRequest name="org.demo.hello.xml.world"
> componentType="osgi.bundle" versionType="OSGi"/>
> </cq:componentQuery>
> I also made a local copy of the rmap likewise, changing the provider info
> to our local CVS (filename: hwdemo.rmap):
> <rmap
> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
> <searchPath name="default">
> <provider readerType="cvs"
> componentTypes="eclipse.feature,osgi.bundle,buckminster" source="true">
> <uri
> format=" :pserver:${user.name}@sam:/usr/local/share/projects/cvsrep,s wt_root/scratch/leet/buckminstertest/helloworld/{0} ">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="default" pattern="^org\.demo\..*" />
> <redirect
> href=" http://www.eclipse.org/buckminster/samples/rmaps/dogfood2.rm ap"
> pattern=".*"/>
> </rmap>
> So I get into my eclipse workbench and do File-> Open component query...
> and enter my url. The CQUERY opens and I click 'resolve to wizard' with my
> fingers crossed - and I get the error at the start of this message. It
> looks like it can't get the component info for this component, right? I do
> a local cvs checkout and confirm that the META-INF dir and plugin.xml file
> are where they are expected and sure enough, there they are (see attached
> screenshot).
> (Embedded image moved to file: pic23281.jpg)
> I assumed this is everything that would be required for successful
> resolution, but no joy...
> I'm left to think that the only possible point of failure is the point at
> which buckminster trys to actually get the component info from our CVS
> repo. Can you suggest a test that I can try locally to try and
> confirm/ruleout this option? Are there specific requirements for
> buckminster CVS support?
> Any help you can provide is greatly appreciated!
> Cheers
> Todd
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
FUDForum. Page generated in 0.05069 seconds
