Home » Eclipse Projects » GEF » How to turn-off the automatically refocusing support for editpart
How to turn-off the automatically refocusing support for editpart [message #42372] Thu, 14 November 2002 22:28 Go to next message
Currently in the GEF editor, when an EditPart is selected , if it is not
completely visible in the canvas, the client area will be refoucsed to
make it visible.
The problem here is I hava a big drawing paper editpart, and everytime I
click anywhere on the paper, the client area will be refocused to the
initial position (with the paper at top-left), and this is really annoying.
My question is is there any way for me turn off the re-focus support for
the drawing paper editpart only, or if it difficult, can I turn off the
re-focusing capability for the whole editor.
Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #42802 is a reply to message #42372] Fri, 15 November 2002 16:26 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Joe" <zhujun@cn.ibm.com> wrote in message
news:ar1pkh$n5r$1@rogue.oti.com...
> make it visible.
annoying.
You "contents" EditPart (a.k.a. drawing paper editpart) cannot be dragged.
It should return MarqueeDragTracker or DeselectAllDragTracker in the method
getDragTracker(Request).
> Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #43114 is a reply to message #42802] Sat, 16 November 2002 01:04 Go to previous messageGo to next message
Thanks Randy, now the problem of automatic refocusing is solved,
But after returning MarqueeDragTracker or DeselectAllTracker from an
EditPart, the EditPart can no longer be selected in the drawing canvas any
longer. Is there any method to solve this new problem?
Randy Hudson wrote:
> \"Joe\" <zhujun@cn.ibm.com> wrote in message
> > make it visible.
> annoying.
> You \"contents\" EditPart (a.k.a. drawing paper editpart) cannot be dragged.
> > Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #43144 is a reply to message #43114] Sat, 16 November 2002 12:07 Go to previous messageGo to next message
news:ar4n5i$4r3$1@rogue.oti.com...
That's not true actually. Anytime nothing is selected, the "contents" is
implicitly selected.
This is why you see in the Logic Example a Connection Router property in the
Property Sheet.
not
> > > make it visible.
I
> > annoying.
dragged.
method
for
the
> > > Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #43181 is a reply to message #43144] Sun, 17 November 2002 20:59 Go to previous messageGo to next message
Sorry I have not described my problem clearly. Yes, the content get
automatically selected by default.
My new problem here is that I have another kind of editpart called "Lane"
in the "contents". Lane is not a container, but it is designed to hold
other editparts. I want to have the lane being selected without
re-centering it in the ClientArea, but currently if I return
MarqueeDragTracker or DeselectAllTracker from the LaneEditPart. Everytime
I want to have the lane be selected by clicking inside of the lane, the
result is the "contents" gets selected.
So I want to know which class is responsible for re-adjust the location of
an editpart when it is selected in GEF implementation classes, and is
there possibility for me to turnoff this capability by overriding certain
methods in this class.
> Property Sheet.
> not
> > > > make it visible.
> I
> > > annoying.
> dragged.
> method
> for
> the
> > > > Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #43370 is a reply to message #43181] Mon, 18 November 2002 08:36 Go to previous messageGo to next message
This behavior is implemented in the various select methods on
AbstractEditPartViewer. We will remove it there, but we will reimplement
this behavior again during keyboard selection changes,
SelectEditPartTracker, and other places, by calling a new method
EditPartViewer#reveal(EditPart).
I knew we were making an assumption that wasn't valid, and now there is a
good example. We added this behavior for keyboard usage. Assuming you have
lanes running vertically, you probably will still want to scroll
horizontally so that keyboard users can navigate across lanes with the
keyboard. Being an IBMer, I'm sure accessibility is a concern of yours.
You'll probably want to extend GraphicalKeyHandler so that up/down (again,
still assuming vertical lanes) scrolls the view vertically by a "line"
increment, without changing focus/selection.
Maybe you have to do nothing at all if we change the way large EditParts are
exposed. Large being defined as an EditPart which cannot be exposed in the
Viewport entirely. If scrolling in the x or y direction does not show more
of the EditPart, then no scrolling along that direction would occur.
You should open a bugzilla. We would appreciate any help here. If you want
to try making the changes yourself, the code to modify/override is found in
ScrollingGraphicalViewer#expose(EditPart) if you are using the Viewer,
otherwise it is in ViewportExposeHelper#expose(EditPart).
any
is
the
> > Property Sheet.
is
> > not
refoucsed to
> > > > > make it visible.
everytime
> > I
the
> > > > annoying.
> > dragged.
> > method
support
> > for
off
> > the
> > > > > Thanks.
Re: How to turn-off the automatically refocusing support for editpart [message #43523 is a reply to message #43370] Tue, 19 November 2002 03:38 Go to previous message
Hi, Randy
The ScrollingGraphicalViewer::expose method is changed as following and
the problem is solved.
protected void expose(com.ibm.etools.gef.EditPart part){
super.expose(part);
Viewport port = getFigureCanvas().getViewport();
IFigure target = ((GraphicalEditPart)part).getFigure();
Rectangle exposeRegion = target.getBounds().getExpanded(5,5);
target = target.getParent();
while (target != null && target != port){
target.translateToParent(exposeRegion);
Dimension viewportSize = port.getClientArea().getSize();
// Zhu Jun(Joe) added here
if (exposeRegion.width > viewportSize.width || exposeRegion.height >
viewportSize.height) return;
Point topLeft = exposeRegion.getTopLeft();
Point bottomRight = exposeRegion.
getBottomRight().
translate(viewportSize.negate());
Point finalLocation = Point.min(topLeft,
Point.max(bottomRight, port.getViewLocation()));
getFigureCanvas().scrollSmoothTo(finalLocation.x, finalLocation.y);
Thanks for help,
> any
> is
> the
> > > Property Sheet.
> is
> > > not
> refoucsed to
> > > > > > make it visible.
> everytime
> > > I
> the
> > > > > annoying.
> > > dragged.
> > > method
> support
> > > for
> off
> > > the
> > > > > > Thanks.
Previous Topic:is it possible to hide connections, like in visual age
Next Topic:Determining bounds for Label text
Current Time: Fri Nov 07 03:42:35 EST 2025
Powered by FUDForum. Page generated in 0.04903 seconds
