Home » Eclipse Projects » Equinox » Product
Product [message #42298] Tue, 11 May 2004 16:46 Go to next message
Sermet Yucel is currently offline Sermet YucelFriend
I have been experimenting with the Product concept. I am not sure I fully
understand how this is supposed to work. I appreciate any clarification.
1- I created a product MyProduct that implements IProduct.
2- I implemented its methods.
3- I added an extension to products extension point in the plugin.xml
4- I launch eclipse with -Declipse.product=MyProduct
5- I created MyProductApplication
6- I created MyproductPerspective
7- I created MyFeature
8- I Created MyPlugin
Is it true that:
1- All application branding data (Except splash screen) comes from the
MyProduct class. This includes the Application name and icon at the top of
the screen. I do not need MyFeature to make this work. I can get rid of
MyFeature. I have seen contradicting postings. One recent posting said
Product id should be the Primary Feature id. In M8, you get a warning if
you assign a product id in plugin.xml, says no such property is found.
Another posting said Product is the whole story now, Feature is the old
way.
2- My application should launch with the MyProductPerspective as default
perpective.
3- MyProduct does not specify the default application. I need to specify
this with -Declipse.application. Why there is a method that returns the
application in IProduct?
4- Declipse.product binds MyProduct to the launched instance of eclipse.
5- Declipse.product argument is working in the releases of May/2004
Re: Product [message #44034 is a reply to message #42298] Mon, 28 June 2004 19:51 Go to previous message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
There is a good section in the Developers doc on packaging products that
should clarify things for you.
Jeff
"Sermet Yucel" <sermety@certusoft.com> wrote in message
news:c7r00b$2nc$1@eclipse.org...
> Is it true that:
> way.
> perpective.
Previous Topic:Now that 3.0 is almost done and RCP is there, is there an equinox?
Next Topic:RCP Splash Screen
Current Time: Mon Jan 13 18:03:13 GMT 2025
Powered by FUDForum. Page generated in 0.08075 seconds
