can not find dv.SWT? [message #41956] |
Wed, 01 June 2005 08:42 |
Originally posted by: yaowang.capitalbio.com
anyone knows how to deal with these errors?
org.eclipse.birt.core.framework.server.ServerPlatform <init>
can't find the plugin folder
[ERR]: org.eclipse.birt.chart.exception.PluginException: $NO-RB$ Unable to
locate any entries for lookup=dv.SWT; element=(name:device) in any
plugin.xml file in all of the available plugins
Re: can not find dv.SWT? [message #42144 is a reply to message #41956] |
Wed, 01 June 2005 14:41 |
Originally posted by: mpadhye.actuate.com
The error seems to be due to the chart device extension plug-in not
being found. The 'dv.SWT' identifies the SWT device for chart rendering
that is registered as an extension in that plug-in.
Can you provide additional details about the problem? What actions do
you perform to see this error? What environment are you running BIRT in?
What version of Eclipse, BIRT? Have you installed EMF? Are all the chart
plug-ins installed? The following plug-ins form the chart library for BIRT:
org.eclipse.birt.chart.engine
org.eclipse.birt.chart.device.extension
org.eclipse.birt.chart.engine.extension
org.eclipse.birt.chart.reportitem
org.eclipse.birt.chart.ui
org.eclipse.birt.chart.ui.extension
Milind
> to locate any entries for lookup=dv.SWT; element=(name:device) in any
Re: can not find dv.SWT? [message #42274 is a reply to message #42144] |
Thu, 02 June 2005 02:42 |
this problem has been solved by adding "System.setProperty("STANDALONE",
"true");"
the new problem is the method LayoutPackageImpl.freeze() can not be found.
platform used is birt-chart-1.0m2 and eclipse 3.0.1
all necessary plugins have been installed
[INFO]: (STANDALONE-ENV) Creating device dv.SWT as
org.eclipse.birt.chart.device.swt.SwtRendererImpl
[INFO]: (STANDALONE-ENV) Creating display server ds.SWT as
org.eclipse.birt.chart.device.swt.SwtDisplayServer
[INFO]: SWT Display Server: win32 v3063
[INFO]: Using graphics context org.eclipse.swt.graphics.GC@GC {-50261434}
java.lang.NoSuchMethodError:
org.eclipse.birt.chart.model.layout.impl.LayoutPackageImpl.f reeze()V
org.eclipse.birt.chart.model.layout.impl.LayoutPackageImpl.i nit(LayoutPackageImpl.java:182)
org.eclipse.birt.chart.model.layout.LayoutPackage.<clinit>(LayoutPackage.java:65)
org.eclipse.birt.chart.model.data.impl.DataPackageImpl.init( DataPackageImpl.java:249)
org.eclipse.birt.chart.model.data.DataPackage.<clinit>(DataPackage.java:65)
org.eclipse.birt.chart.model.attribute.impl.AttributePackage Impl.init(AttributePackageImpl.java:779)
org.eclipse.birt.chart.model.attribute.AttributePackage.<clinit >(AttributePackage.java:67)
org.eclipse.birt.chart.model.component.impl.ComponentPackage Impl.init(ComponentPackageImpl.java:171)
org.eclipse.birt.chart.model.component.ComponentPackage.<clinit >(ComponentPackage.java:65)
org.eclipse.birt.chart.model.type.impl.TypePackageImpl.init( TypePackageImpl.java:144)
org.eclipse.birt.chart.model.type.TypePackage.<clinit>(TypePackage.java:66)
org.eclipse.birt.chart.model.impl.ModelPackageImpl.init(Mode lPackageImpl.java:125)
org.eclipse.birt.chart.model.ModelPackage.<clinit>(ModelPackage.java:63)
org.eclipse.birt.chart.model.impl.ChartWithAxesImpl.eStaticC lass(ChartWithAxesImpl.java:168)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eClass(BasicEObj ectImpl.java:785)
org.eclipse.emf.ecore.util.EcoreUtil$Copier.createCopy(Ecore Util.java:392)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copy(EcoreUtil.j ava:358)
at org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:296 )
at org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:135)
birtTest.TestLineChart$MyPaintListener.paintControl(TestLine Chart.java:78)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:82)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:80 3)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3020 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3338 )
at org.eclipse.swt.internal.win32.OS.UpdateWindow(Native Method)
at org.eclipse.swt.widgets.Decorations.setVisible(Decorations.j ava:1213)
at org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1175)
at org.eclipse.swt.widgets.Shell.open(Shell.java:767)
at birtTest.TestLineChart.main(TestLineChart.java:103)
Re: can not find dv.SWT? [message #42339 is a reply to message #42274] |
Thu, 02 June 2005 14:49 |
What version of EMF do you have installed? In EMF 2.0.1 the freeze()
method exists in the EPackageImpl class which LayoutPackageImpl extends.
Milind
> "true");"
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03111 seconds
