Re: Agent Controller for iSeries [message #4378 is a reply to message #3597] |
Tue, 01 February 2005 21:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Samson Wai![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=samwai%40ca.ibm.com) Messages: 46 Registered: July 2009 |
Member |
The profiling agnet (piAgent) is a multi-threaded service program. You will
need to turn on multi-thread in QShell using the command:
export QIBM_MULTI_THREADED=Y
in order for the profiler to bootstrap correctly. This is already handled
when the application is remotely launched for profiling.
Samson
"Chris DeLashmutt" <chris.delashmutt@leaseplan.com> wrote in message
news:ct67na$vv6$1@www.eclipse.org...
> Has anyone had any luck trying to get Hyades/IBM Agent Controller (from
> WSAD) on any version of iSeries working properly? I've gotten the agent
> application (RASERVER) loaded and running on V5R1, but when I try to
> attach to the agent from WSAD 5.1.2 on my workstation, I get no agents in
> my list. I'm starting the RASERVER job first, and then trying to start a
> small Java 1.3.1 application from QSH like this (replacing the <> values
> with appropriate values): "java -cp <classpath> -XrunpiAgent <myClass>".
> The -XrunpiAgent is supposed to cause the Hyades system to begin receiving
> profiling information from the JVM so that I can view it in WSAD.
> Here are some of the things I "know" so far:
> - My workstation is attaching at least partially because I get a
> connection error in WSAD when the RASERVER job isn't running when I try to
> attach, but no errors if the job is started when I attach.
> - The iSeries JVM is finding the PIAGENT service program in the HYADES
> library, because if I rename that program, and use the "-XrunpiAgent"
> parameter on my call to java, the JVM won't start.
> - I can use the "Launch" function to successfully launch a new process
> through the agent and profile it.
> It seems like I'm really close, but I'm just missing something. I'll be
> glad to post whatever anyone wants if someone needs a config file or
> something.
Re: Agent Controller for iSeries [message #4931 is a reply to message #4378] |
Wed, 02 February 2005 23:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris DeLashmutt![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=chris.delashmutt%40leaseplan.com) Messages: 2 Registered: July 2009 |
Junior Member |
Thanks, Samson. That works great.
Just for information purposes, I was also trying to get this running on
the iSeries with WebSphere. I was able to do that by making sure that the
HYADES library was on the library list for the user profile that runs the
Administrative server jobs for WebSphere. For WAS 4, that was the QEJBSVR
user profile, which was using the QDFTJOBD on my system. That JOBD was
using the system value for default library list, so I added the HYADES
library to the system value. Then I was able to start the WebSphere
server, and attach to it from the WSAD profiling tool. Very cool!
Samson Wai wrote:
> Samson
>> something.
FUDForum. Page generated in 0.03092 seconds
